I can not assign error message
Hello everyone,
I can’t do anything with this error message. I’ve searched the forum but haven’t found anything.
Fehlermeldung:
Logger: homeassistant.config
Source: config.py:982
First occurred: 13:04:56 (1 occurrences)
Last logged: 13:04:56
Invalid config for [template]: [template] is an invalid option for [template]. Check: template->template. (See ?, line ?).
Home Assistant runs on Windows, Virtual Box
Home Assistant 2023.2.5
Supervisor 2023.01.1
Operating System 9.5
Frontend 20230202.0 - latest
I’m an absolute novice.
I am grateful for any help.
Excuse my Google English
greeting
Wolfgang
Share the template: section of your configuration.yaml file
Hello Tom, thanks for your help.
/config/configuration.yaml
Loads default set of integrations. Do not remove.
default_config:
recorder:
db_url: mysql://homeassistant:xxxxxxxxxxx@core-mariadb/homeassistant?charset=utf8mb4
commit_interval: 1
purge_keep_days: 2000
Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
Text to speech
tts:
  • platform: google_translate
#Configuration.yaml - Auslagerung
template: !include template.yaml
/config/template.yaml
wasserzaehler
template:
device_class: water
unit_of_measurement: “m³”
state_class: “total_increasing”
icon: “mdi:water-percent”
accuracy_decimals: 3
lambda: |-
return id(total_pulses) * 0.01;
Please edit your post and format it correctly:
https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371#oneone-format-it-properly-16
Post your configuration.yaml again then make sure there is a blank line in the top and bottom.
Then mark the entire text inclusive the two blank lines and click the </> icon in the top of the text editor and then post it.
Next do the same for your template.yaml file.
Better if they edit their post as Tom asked, rather than re-posting it all.
Images of text are a horrible thing, but remove the second line of template.yaml, and remove the first two spaces of every line in that file.
configuration.yaml
# Loads default set of integrations. Do not remove.
default_config:
recorder:
  db_url: mysql://homeassistant:xxxxxxxxxxxxcore-mariadb/homeassistant?charset=utf8mb4
  commit_interval: 1
# Load frontend themes from the themes folder
frontend:
# Text to speech
tts:
  - platform: google_translate
template.yaml
# wasserzaehler
  template:
    device_class: water
    unit_of_measurement: "m³"
    state_class: "total_increasing"
    icon: "mdi:water-percent"
    lambda: |-
You don’t need (and don’t want) template: in that file, and you’ve got too many spaces. It should look like
# wasserzaehler
  device_class: water
True. I did not see Tom’s suggestion when I posted mine. Guess it was a dirty write. :wink:
Thank you so much. the error message is finally gone.
Please excuse my ignorance in the forum.
Greetings Wolfgang
