I had this same issue. Followed instructions in ESPhome github (https://github.com/esphome/issues/issues/805#issuecomment-555255432). Since I am running HA on Raspbian (i.e. armv7l), I changed the Toolchain to the âarm-linux-xxxxâ instead. I.e. the full command inside the container would be: curl -L https://github.com/earlephilhower/esp-quick-toolchain/releases/download/2.5.0-4/arm-linux-gnueabihf.xtensa-lx106-elf-b40a506.1563313032.tar.gz | tar --strip-components=1 -xzf - -C /root/.platformio/packages/toolchain-xtensa/
To be honest, I donât exactly know what it does and why it works, but for me it did the trick.
For anybody getting errors like xtensa-lx106-elf-g++: internal compiler error: Segmentation fault (program cc1plus) on RPis, please run rpi-update and confirm youâre running firmware v4.19.80 or newer installed.
I had the same error and while I was able to solve my error by following the below instructions : I ran into another error while running the compiled binary on the ESP. It resulted in an exception.
I had to delete the contents of the toolchain-xtensa directory inside docker first else it did not work.
Also after deleting and getting its contents afresh , on my first compile ESPHome installed the toolchain-xtensa files as below: INFO Reading configuration /config/esphome/tank_controller.yaml... INFO Generating C++ source... INFO Compiling app... INFO Running: platformio run -d /config/esphome/tank_controller Processing tank_controller (board: d1_mini; framework: arduino; platform: [email protected]) PackageManager: Installing toolchain-xtensa @ <3 Downloading [####################################] 100% Unpacking [####################################] 100% toolchain-xtensa @ 2.40802.191122 has been successfully installed! HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
I was able to compile well. I am using RPi3, Hassio/Buster/addon ESPHome 1.14.3
But ran into the following exception on the ESP and it kept rebooting:
Exception 29: StoreProhibited: A store referenced a page mapped with an attribute that does not permit stores** PC: 0x4020c39a EXCVADDR: 0x00000000 *Decoding stack results* 0x4023218a: **scalbn** at ../../../../../../dl/newlib-xtensa/newlib/libm/common/ **s_scalbn.c** line **93
I was having problems when compiling my EspHome nodes. I found that you need to have at least 500MB of free memory to compile. Once I freed memory the errors stopped.
Same error on rpi4 running hassio on raspbian buster. The fix for me was to run âplatformio updateâ in the esphome container. What sucks is you have to do this every time you start the container. I ran platformio in the container from a shell and it did the same thing.
Thank you for this. I spent hours trying to get this to work. Have you found any other work-arounds, or are we just waiting for 4.19.80 firmware at this point?
Hello, same problem here, EspHome Crashing my Rpi4 1 Gb.
I managed to run platformio update in the container.
Now I want to run esphome manually also in the container to check that it works, before I try it from hassio.
How can I do that?
docker exec a1024e1c6a77 esphome config living.yaml
This gives me errors
