I can not find Schlage option in the integration on the home assistant cloud 2023.9.0
Hi there
So, I received the notification “The Schlage custom integration is deprecated”, and I was going to rebuild schlage lock integration by using the native home assistant workflow, but I can not find “Schlage” option in the integration options.
The home assistant core version is 2023.9.0.
For now, I can see only Schlage Custom integration option in the integration.
So, what should I do to fix this issue? I already checked the Github issues, and they are asking to update the HA version to 2023.9.0. But it is already done in my HA instance.
Looking forward to your update.
Regards
The custom component and the native integration have the same name, so you have to delete the custom integration for the native one to be visible.
Hi @koying
Thank you for your reply.
I understand you, so how can I delete the custom integration properly?
As you know, there is already configured Schlage integration on Devices & services page.
So I guess the correct steps are the following ones.
I have to delete this integration on the Devices & Services page first of all, delete the schlage custom component on the Studio code server page, restart the HA instance, and finally add the native Schlage integration on the Devices & Services page.
Am I right?
Thanks.
Seems right, yes
