i have ran ha on a pi 4 and i needed to re-flash ha on to a new usb and it seemed normal but i can not login to the web dashboard it is just the crome time out page or the connection refused HELP PLZ
Here are some things to try:
Have you tried connecting a display to the Pi’s HDMI connector to see if anything looks bad when you start up?
Is it possible HA now has a different IP address and you are still trying to use the old one?
Are any automations you have set up still running and doing things automatically? If you are using Alexa or Google Home, can you still control things?
i have the displa cected and it is just normal and i do have the ip from my rooter and it is the same i have just restarted it for the 90th time so
What are you using as the address for the web page?
