I can’t see my zwave controller. UI integration card display
THANKS in advance for looking at my multipart question. I’m missing something, whether from poor search choices or swiss-cheese brain is unclear. I keep ending up with the same search results and have run out of key words & tricky phrases to try. :wink:
~watersprite~
Q: Should the zwave integration card list my controller?
Q: How long should the zwave server take to start the first time on a small network?
The configuration page linked from this card tells me the zwave server isn’t running and has no nodes or hardware listed. I tried the ‘ start server’ button multiple times but it just spins & never starts. I have one zwave Thing ( GE outdoor smart plug ) and after 30-40 minutes still nothing. Do I just need to wait longer?
log file has no messages about zwave, only synology.
OZW log created, but won’t load into integration.
2020-12-14 23:03:49.963 Info, Setting Up Provided Network Key for Secure Communications
2020-12-14 23:03:49.964 Info, mgr,     Added driver for controller /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_C130238D-if01-port0
2020-12-14 23:03:49.964 Info,   Opening controller /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_C130238D-if01-port0
2020-12-14 23:03:49.964 Info, Trying to open serial port /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_C130238D-if01-port0 (attempt 1)
2020-12-14 23:03:49.967 Info, Serial port /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_C130238D-if01-port0 opened (attempt 1)
2020-12-14 23:03:49.968 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-12-14 23:03:49.968 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-12-14 23:03:49.968 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-12-14 23:03:49.968 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-12-14 23:03:49.968 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-12-14 23:03:49.968 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-12-14 23:03:50.968 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-12-14 23:03:50.968 Detail, contrlr, Removing current message
2020-12-14 23:03:50.968 Detail, contrlr, Notification: Notification - TimeOut
2020-12-14 23:03:50.969 Detail,
2020-12-14 23:03:50.969 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-12-14 23:03:51.969 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-12-14 23:03:51.969 Detail, contrlr, Removing current message
2020-12-14 23:03:51.970 Detail, contrlr, Notification: Notification - TimeOut
2020-12-14 23:03:52.614 Detail,
2020-12-14 23:03:52.614 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-12-14 23:03:53.615 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-12-14 23:03:53.615 Detail, contrlr, Removing current message
2020-12-14 23:03:53.615 Detail, contrlr, Notification: Notification - TimeOut
2020-12-14 23:03:53.617 Detail,
2020-12-14 23:03:53.617 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-12-14 23:03:54.617 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-12-14 23:03:54.617 Detail, contrlr, Removing current message
2020-12-14 23:03:54.618 Detail, contrlr, Notification: Notification - TimeOut
2020-12-14 23:03:54.618 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-12-14 23:03:55.618 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2020-12-14 23:03:55.618 Detail, contrlr, Removing current message
2020-12-14 23:03:55.619 Detail, contrlr, Notification: Notification - TimeOut
2020-12-14 23:04:57.577 Warning, WARNING: Out of frame flow! (0x11).  Sending NAK.
2020-12-14 23:04:58.556 Warning, WARNING: Out of frame flow! (0x1a).  Sending NAK.
2020-12-14 23:05:00.504 Warning, WARNING: Out of frame flow! (0x11).  Sending NAK.
2020-12-14 23:05:02.503 Warning, WARNING: Out of frame flow! (0x11).  Sending NAK.
Supervisor version 2020.12.6
Operating System Home Assistant OS 5.8
Hardware:.
Raspi 4 8GB
With
64GB Micro SD (Video MicroSDXC - C10, U3, V30, 4K UHD)
Zwave controller:
Nortek HUSBZB-1
on 6’ usb extension cord.
( the zigbee side shows up in the zigbee UI integration card. I haven’t tried to add any Things to it yet. )
From Home Assistant
Supervisor/system/ Hardware
serial:
  - /dev/ttyUSB0
    /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_C130238D-if00-port0
  - /dev/ttyUSB1
  - /dev/ttyAMA0
I’m using
configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
#default_config:
#config:
discovery:
history:
frontend:
logbook:
#zwave:
# usb_path: /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_C130238D-if01-port0
#/dev/ttyUSB0
# config_path: /usr/local/share/python-openzwave/config
# polling_interval: 10000
#mqtt:
# broker: 192.168.1.115
# calendar
#client_id: 324728644919-49li7prp80j57mc4tavscu7kdaf39rcm.apps.googleusercontent.com
# -client_secret: f-nIY7ZM1T0nfdrdJGfAwjNr
#google: !google_calendars.yaml
# Text to speech
tts:
- platform: google_translate
#------ Move out to other files
automation: !include automation.yaml
#zone: !include zone.yaml
sensor: !include sensor.yaml
switch: !include switch.yaml
device_tracker: !include device_tracker.yaml
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
#frontend: !include frontend.yaml
#themes: !include_dir_merge_named themes
system_health:
I thought the Z-Wave part of the stick is /dev/ttyUSB0 (or /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_C130238D-if00-port0) and the Zigbee part is /dev/ttyUSB1 (/dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_C130238D-if01-port0)
But I could easily be mistaken as I don’t have that device.
Yes! Thank You!
Follow up question
Since I used the UI to set this up, there is nothing for it in my configuration.yaml file. I ‘edited’ by deleting and adding the zwave integration through the UI. What is the proper way to edit this? Where is the info saved & is it safe to edit directly?
Thanks again!
Honestly I have no idea where the “UI integrations” configuration is stored. I suppose if you do find them it shouldn’t be an issue to edit them directly as it should all be based on the same YAML formatting.
