I cannot add my Nuki Smartlock Pro to HA via Matter & Homekit again
Hello Community,
I am running HA in a docker container. I have a Nuki Smartlock Pro and it was integrated into HA via Matter with my Apple Homepod Mini being the boarder router. A few days back, I had to setup my Nuki Smartlock Pro again and therefore deleted it from HA and Homekit.
I was able to add it to homekit again but it seems I cannot add it back to HA. I tried several ways (existing or new integration) and none worked.
I believe the way it should work… I go into my Apple Home app and start the pairing mode for the lock which gives me a “configuration code”. I then go to the matter entry in HA and add a new integration. Then I select “existing device” and enter the code. After a few seconds, nothing happens, except that the entry field is active again.
Any idea what I could do to make it work again?
Thanks!
