While my current setup had these issues with installing some addons, I created a fresh VirtualBox VM on linux Debian 11, downloaded the VM image @ https://github.com/home-assistant/operating-system/releases/download/9.4/haos_ova-9.4.vdi.zip and after I created my account,
I logged in and tried to install Grafana Add-On. I got this error,
which seems to be a common error which says: “YUP we don’t have a clue as well”
The same error happens while trying to install StudioCodeServer, Node-Red
Some addons do instal fine (File Editor, Terminal & SSH, Samba Share)
DNS seems OK, or does this ping returns wrong IP’s?
Thanks Wally
I just tried to install some ‘official’ add-ons first, it worked. Then I could install Studio Code Server and Node-red like nothing happened. Grafana still does not install…
Anyways, installing some official add-ons first is probably not of any influence
I have just come across this. I cant install any official add ons, but I can installed repository added ones??
I have tried SSH, visual, samba and not are installing, i get this error
Can't install homeassistant/amd64-addon-samba:10.0.0: 404 Client Error for http+docker://localhost/v1.41/images/homeassistant/amd64-addon-samba:10.0.0/json: Not Found ("no such image: homeassistant/amd64-addon-samba:10.0.0: No such image: homeassistant/amd64-addon-samba:10.0.0")
Yeah, today I wanted to re- install Mosquitto broker, but no, same story. HA also restarts often when trying to install.
After 100s of tries, it finally installed…
Grafana still does not want to install, with similar error msgs.
Trying it every day for 1 or more times…
It’s very odd, I don’t read very much about this issue. The problem should be Github?
All HACS installs works fine though
The Grafana issue I reported got swiped off the table (not our problem):
