I cannot install Home Assistant OS in virtual machine
Hi! I am trying to install Home Assistant on both VMware and Virtual box. I have a windows minipc. I have followed all the setup steps on the website, but there is no way to get the installation to start. It gives an error. I send you the error that comes out. Let’s see if you can help me. Thank you very much!
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
[supervisor.docker.interface] Updating image ghcr .io /home -assistant/qemux86-64-homeassistant:landingpage to ghcr .io/home- assistant/qemux86-64-homeassistant:2024.3.0
[supervisor.docker.interface] Downloading docker image ghcr .io/home-assistant/qemux86-64-homeassistant with tag 2024.3.0.
[supervisor.docker.interface] Can’t install ghcr .io/home -assistant/qemux86-64-homeassistant:2024.3.0: 500 Server Error for http+docker://localhost/v1 .43/images/create?tag=2024.3.0& fromImage=ghc r.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error (“Get “https://ghcr.io/v2/”: net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)”)
[supervisor.docker.interface] Updating image ghcr .io/home-assistant/qemux86-64-homeassistant :landingpage to ghcr .io/home-assistant/qemux86-64-homeassistant:2024.3.0
[supervisor. docker.interface] Downloading docker image ghcr .io/home-assistant/qemux86-64- homeassistant with tag 2024.3.0.
Make sure the VM can connect to internet. Now it seems that it can’t.
Put the error text into code tags, “</>”. This keeps the formatting clean.
Is there a reason you are using a VM? If the mini-pc is only to be used with Home Assistant, just install HAOS to the boot device.
