I cannot navigate to home menu
My Home Assistant mobile App (for Android) starts automatically in one of my Dashboards (it was the default dashboard and I edited it). I cannot navigate to the main menu. I only see this dashboard. Tapping on the “back” button (red in the screenshot) has no function.
That means, that I cannot switch between the dashboard and I cannot go to the menu screen.
Any ideas, what I could have messed up with home assistant?
Hi MSco
Have you tried first …
  • killing the HA companion app on your android phone and restart it … (on my iphone this helps)
  • acess your HA server via your phone browser … (via http://homeassistant.local:8123/ )
You will need to explain what and how you have been editing the dashboard …
Hope to have helped
@GSVerspecht Thanks for your help.
I have the problem on multiple phones. Reinstalling the app did not work, unfortunately.
In the browser, I have the same problem in the mobile view. In the Desktop view, everything is fine.
I added some switches and covers to my home dashboard. Here is the code:
  - title: Home
    icon: mdi:home
    subview: true
    type: sidebar
    badges: []
    cards:
      - type: entities
        entities:
          - entity: switch.kuche_warmwasser_sockel_1
            name: Küche Warmwasser
          - entity: light.homeatic_ip_access_point_badezimmer_luftung
          - entity: switch.wz_lampe_2_sockel_1
            name: WZ Lampe 2
          - entity: switch.testdose_sockel_1
            name: WZ Lampe 3
          - entity: switch.lampe_draussen_sockel_1
        title: Schalter
      - type: entities
        entities:
          - entity: cover.homeatic_ip_access_point_rollladen_kuche
          - entity: cover.homeatic_ip_access_point_rollladen_wohnzimmer_links
          - entity: cover.homeatic_ip_access_point_rollladen_wohnzimmer_rechts
          - entity: cover.homeatic_ip_access_point_rollladen_schlafzimmer_barbara
          - entity: cover.homeatic_ip_access_point_rollladen_schlafzimmer_martin
          - entity: cover.homeatic_ip_access_point_rollladen_kinderzimmer_links
        state_color: true
        title: Rollladen
        show_header_toggle: false
title: Home Dashboard
Try changing the default dashboard, had another user encounter the same issue and I think that is what fixes it for them.
Ok, I got it! With a new dashboard I didn’t have this issue. So I copied step by step my dashboard code into the new dashboard. With the exact same code, the issue still occured.
Removing the line subview: true solved my issue.
I don’t know how this line came there and what this line does, but without that line, everything works fine.
Thank you guys! :slight_smile:
Thank you, had the same problem, and that was the solution, namely: "Removing the line subview: true"
I had exactly the same issue. The solution works also.
