I want to delete a Zigbee device. I removed it from MQTT, but I get the following error when I try to remove it from Zigbee2MQTT. The next day, the device is in MQTT again. How can I delete it?
I have not tried it. I believe that the “Force” option is only for desperate situations when nothing else succeeds. For now, I am just exploring what other options I have without using the Force option.
There are no other options to explore. Force delete does what you want, or you can do it manually from the db. (not recommended).
Okay, thank you. I removed it using Force option.
