I can't add the Pushover Integration to HomeAssistant
neither the “add integration”-button works (upon clicking it I get the error “This integration does not support configuration via the UI. If you followed this link from the Home Assistant website, make sure you run the latest version of Home Assistant.”), neither does it appear in my frontends’ integration list
I tried adding it manually into my config.yaml like in this 3y old video and that works.
Home Assistant core 2022.5.5
Home assistant supervisor, 2023.07.1
Home assistant, OS 7.4
I’m open to alternative programs too as long as they work on iOS and are capable of shared notifications as in you receive or dismiss one on one device and it is received or dimissed on the others as well.
Have you considered updating your HA environment ?
I don’t really like doing that because I did it several times in the past and most of the times something broke
Sorry to hear, however i do believe you are “Bound”. to in very near future ( unless you just don’t expand, trying to add new integrations/add-ons/custom-cards etc), might aswell get over it.
