malosaa
(Hector)
1
Hello people,
Well i don’t know if i can ask it in here.
The problem is this, I checked out a tutorial from frigate, there is a way to change the video directory.
I did setup my fstab, but /usr/share/hassio folder does not exist on my system.
When i go to cd /usr/share there is no folder called hassio?
I’m using last HA OS Virtualbox 7.5
How can i do it ?
When i go to cd /etc and then nano fstab
I can add the //192.168.1.6/test usr/share/hassio/media cifs username=XXX,password=XXX,iocharset=utf8 0 0
But doesnt mount when run mount -a folder not found.
Regards
nickrout
(Nick Rout)
2
You are posting in the haos section, but pointng to instructions for a supervised install.
tmjpugh
(Tmjpugh)
3
Network folder? Maybe networking not ready when mount attempted
Tinkerpop
(Praveen Madhavan)
4
@malosaa Did you ever find out a solution for this?
malosaa
(Hector)
5
yes on my other system i got it working like this ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=10)
add this in configuration.yaml
shell_command:
mount_domotic_media_folder: mkdir -p /config/www/media/domotic;mount -t cifs -o username=********,password=********** //192.168.4.22/Do /config/www/media/domotic
Than make an automation that start when HASS starts and when its executed you can go to MEDIA and then LOCAL MEDIA and there it is your folder.
@Tinkerpop
Tinkerpop
(Praveen Madhavan)
6
Thank you! I will check this out.
