Hello everyone I can’t connect NodeMCU to HA. Asks for the WIFI password and login. But if I specify, the syntax swears at the password that it must be at least 8 characters long. My password is already 8 characters long. What am I doing wrong?
INFO ESPHome 2024.2.2
INFO Reading configuration /config/esphome/esphome-web-f5506b.yaml...
Failed config
wifi: [source /config/esphome/esphome-web-f5506b.yaml:20]
ssid: !secret wifi_ssid
WPA password must be at least 8 characters long.
ap:
ssid: Esphome-Web-F5506B
password: Em9A2QwIpJoM
sensor.sensor: [source /config/esphome/esphome-web-f5506b.yaml:32]
Platform not found: 'sensor.sensor'.
platform: sensor
pin: D3
model: SHTCx
temperature:
humidity:
update_interval: 10s
This one definetely stopping configuration to compile.
Fix sensor configuration. Or remove it for first try.
Just to connect device to WiFi and HA, then add sensors etc.
If I remove the sensor configuration, the error on it disappears. But the wifi error will remain. I am entering the correct wifi data. The syntax still swears at the number of characters in the password.
If your WiFi password is less than 8 characters then change it to one that is at least 8 characters.
It is a standard to require that on most devices, so it will not just be ESPHome you will be fighting with.
