I have Home Assistant in a Raspberry Pi 4. HAss is working fine and I can connect it local (homeassistant:8123 or with my internal IP:8123) and remotely (Nabu Casa). But every time I try to login in my Raspberry pi via Putty, I get this message: “Network error: Connection refuse”. What could be the problem? I have always been able to login to my Raspberry pi via Putty.
Assuming you are using Home Assistant OS…
Did you install and start the SSH addon?
Hey!
I saw this soulution for using putty
I’d like to update und upgrade the raspberry. This is not possible with the
sudo apt-get update
sudo apt-get upgrade
in a terminal session with the plugin?
Frank
That is not how you update Home Assistant OS.
You will be notified when there is an OS upgrade to install from the UI.
Sorry! As a noob - I mean to update the OS … ; )
Yes, that is what I said, you don’t do that with apt-get for HA OS.
