I decided to consolidate my multiple Zigbee HUB’s setup to a single Sonoff USB stick using ZHA, and I ran into a problem.
Namely, my Aqara D1 Wall Switches don’t pair with my ZHA. Whenever I press and hold the D1 Wall Switch to initiate pairing, my Xiaomi Mi Gateway says something in Chinese but the D1 switch does not appear in ZHA.
All my other Aqara devices got migrated to ZHA with the same process flawlessly.
Pairing worked once I unplugged the Xiaomi Mi Gateway HUB
Looks like the D1 Wall Switches don’t want to leave their master, but are happy to find a new master once the old one is gone
These switches have a problem (or at least a variant of them) where they have issues re-pairing once losing power. Mine is just a basic switch at this point because apparently one of the only ways to fix it is to connect them via UART to a computer and delete the memory.
Would personally avoid aqara switches if you’re gonna use them with home assistant zigbee adapter directly.
