I can't get Groups working
I’ m tring to setup two groups so i can trigger automations when house is empty or someone arrives.
I put this in configuration.yaml
group: !include_dir_merge_list groups/
and this in a file in groups folder called group1.yaml
mylights:
 entities:
    - switch.bf91f02356a4f11df8dbdx
    - switch.interruptor3
familia:
 entities:
      - person.ha
but no new entities called family or mylights in developer tools (it should appear there right?)
what i m doing wrong?
and the next step would to set up a automation so that these lights go on if someone in the group arrives at home and its night.
thanks a lot!
Your include appears off to me.
With your groups directory at the same level as your configuration.yaml it should be
After a restart your groups should be listed in developer tools.
it doesn’t work (even without the /)
i just changed it to default group: !include groups.yaml and put the group in group.yaml and it works…so not sure what its wrong as i’m doing exactly the same for sensors. i really dont have the need to use another directory for groups so i will use groups.yaml
Permissions on the created folder perhaps?
include_dir_merge_list will look only for YAML list elements (things with the ‘-’)
You need include_dir_merge_named.
group: !include_dir_merge_named groups/
