I am new to Home Assistant and coding just for hooby as an amateur.
My tuya thermostat return 2 paramater for hvac_mode: Off and Heat/Cool
When I look at the service which can be called I can see Heat and Cool parameters.
How can I get these and add as new icon to the bootom of the card. I am using this template:
Serivce page:
service: climate.set_hvac_mode
hvac_mode: heat
entity_id: climate.termostat
My code:
type: grid
cards:
- type: custom:simple-thermostat
entity: climate.termostat
header:
toggle:
entity: switch.child_lock
icon:
auto: mdi:radiator
cooling: mdi:snowflake
heating: mdi:radiator
idle: mdi:radiator-disabled
'off': mdi:radiator-off
cool: hass:snowflake
heat: hass:fire
heat_cool: hass:power
'on': hass:power
layout:
step: column
mode:
names: true
icons: true
headings: false
unit: null
decimals: 1
step_size: 0.5
label:
temperature: Room
state: State
hide:
temperature: true
state: true
sensors:
- entity: sensor.temperature
- entity: sensor.humidity
control:
hvac:
hvac_mode: true
'off':
icon: mdi:lightbulb
heat_cool:
icon: mdi:power-standby
heat:
hvac_mode: heat
cool:
hvac_mode: cool
