LeonardoCT
(Leonardo Ct)
1
No matter what docker container i try to install i allways get
“Failure starting container with non-empty request body was deprecated since API v1.22 and removed in v1.24”
All i want to do is install OwnCloud on HA so if anybody knows how to fix Portainer or any other way to run OwnCloud Please help me
tom_l
2
What type of Home Assistant installation do you have?
LeonardoCT
(Leonardo Ct)
3
version: core-2021.10.4
installation_type: Home Assistant OS
tom_l
4
This is not what the Portainer addon is for. It says so quite clearly in the documentation.
If you want to install and manage your own containers you need to install Home Assistant using the Container method.
LeonardoCT
(Leonardo Ct)
5
Oh yes yes i knew that but it looks like the only way to easly run docker containers inside of home assistant
tom_l
6
Nope. Not what it is for. It says so quite clearly, it is for debugging only.
LeonardoCT
(Leonardo Ct)
7
Allright sir this was so helpfull
Thanks for your time
