I’ve spent all day trying to install the Apollo Air 1. I keep running different error messages Each time I install. At first I was getting this error message ‘‘idf_tools.py installation failed’’ I tried reinstalling Python on the host machine with The recommended version and a certain check box selected. Then II updated Home Assistant and Home Assistant core and did a reset.
After that I completely uninstalling ESP Home dev with files, restarted and then went directly into The install process With the Apollo Air One in factory state. This time I got this result.
INFO ESPHome 2025.11.0-dev
INFO Reading configuration /config/esphome/apollo-air-1-f8f514.yaml...
INFO Generating C++ source...
INFO Core config or version changed, cleaning build files...
INFO Compiling app... Build path: /data/build/apollo-air-1-f8f514
Processing apollo-air-1-f8f514 (board: esp32-c3-devkitm-1; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32/releases/download/55.03.31-1/platform-espressif32.zip)
Platform Manager: Installing https://github.com/pioarduino/platform-espressif32/releases/download/55.03.31-1/platform-espressif32.zip
INFO Installing https://github.com/pioarduino/platform-espressif32/releases/download/55.03.31-1/platform-espressif32.zip
Downloading [####################################] 100%
Unpacking [####################################] 100%
Platform Manager: [email protected] has been installed!
INFO [email protected] has been installed!
INFO tool-esp_install not installed, installing version https://github.com/pioarduino/esp_install/releases/download/v5.3.2/esp_install-v5.3.2.zip
INFO Installing tool-esp_install version https://github.com/pioarduino/esp_install/releases/download/v5.3.2/esp_install-v5.3.2.zip
Tool Manager: Installing https://github.com/pioarduino/esp_install/releases/download/v5.3.2/esp_install-v5.3.2.zip
INFO Installing https://github.com/pioarduino/esp_install/releases/download/v5.3.2/esp_install-v5.3.2.zip
Tool Manager: [email protected] has been installed!
INFO tool-esp_install successfully installed and verified
Created pioarduino Python virtual environment using uv: /root/.platformio/penv
Error: uv installation timed out
Error: Failed to install Python dependencies into penv
