I can't see node-red in the tab "add on"
Good afternoon, I’m trying to install node-red in home assistan.
I can’t see node-red in the tab “add on”
should i set something up?
help, thanks
http://letmegooglethat.com/?q=home+assistant+node+red+addon
I’ve been searching for more than 5 hours and I haven’t found.
Haven’t found what?
First result on Google search is the github for the addon, which tells you it’s in the community addon repo.
On the community addon repo page, under installation it says…
In general, there is no need to install this repository on your Home Assistant instance. It is activated and added by Home Assistant by default.
However, if the repository is missing on your setup, adding this add-ons repository to your Home Assistant instance is pretty easy. In the Home Assistant add-on store, a possibility to add a repository is provided.
Use the following URL to add this repository:
https://github.com/hassio-addons/repository
it worked thanks
