I can't set up mqtt
Where am I making a mistake? I don’t think I understand any part of the manual. I’m confused
Two things I’d suggest; if you go to supervisor / dashboard and click on the MQTT box there are tabs across the top, the ‘log’ tab will show what is happening, and any errors that occur. The other thing you need to do so that HA can discover the new tasmota device is go to the console tab on the device webpage and enter SetOption19 1 which will make the device send the messages necessary for HA to find the device.
Try that and if it’s still not working I suggest you post the log and someone will try and help point you in the right direction.
thanks, thanks, thanks
it’s already working
I don’t know why the original documentation is so “complicated” and at the same time “stupid” …
I came across the command “SetOption19 1” somewhere in the manuals, but perhaps only once and just didn’t understand its function.
Thanks again
now I’m going to wash with ESP …
Glad you got it working :grinning:
