Today I updated my sonoff zigbee 3.0 usb dongle plus v2. But I can’t start it because it keeps giving the following errors.
I’ve been working on this all day. I think I’ve read everything, but I can’t get it to work.
The logs are for z2m, the screen shots look like ZHA. Which are you trying to use? You can’t have both with a single coordinator.
Thanks for your answer.
I don’t understand this now. It worked like this before the update.
There have been several Zigbee updates, but this error always occurred when I updated. Yesterday I started updating Sonoff too, so that everything is up to date, but now I can’t get it to work.
Zigbee is the coordinator, right?
But on Sonoff is mistakes here too.
2024-12-21 07:21:46.862 DEBUG (MainThread) [homeassistant.components.zha.repairs.wrong_silabs_firmware] Failed to probe application type
File "/usr/local/lib/python3.13/site-packages/bellows/uart.py", line 109, in reset
return await self._reset_future
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 151, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/local/lib/python3.13/site-packages/zha/application/gateway.py", line 275, in async_initialize
await self._async_initialize()
File "/usr/local/lib/python3.13/site-packages/zha/application/gateway.py", line 258, in _async_initialize
await self.application_controller.startup(auto_form=True)
File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 220, in startup
await self.connect()
File "/usr/local/lib/python3.13/site-packages/bellows/zigbee/application.py", line 150, in connect
await self._ezsp.connect(use_thread=self.config[CONF_USE_THREAD])
File "/usr/local/lib/python3.13/site-packages/bellows/ezsp/__init__.py", line 138, in connect
await self.startup_reset()
File "/usr/local/lib/python3.13/site-packages/bellows/ezsp/__init__.py", line 127, in startup_reset
await self.reset()
File "/usr/local/lib/python3.13/site-packages/bellows/ezsp/__init__.py", line 146, in reset
await self._gw.reset()
File "/usr/local/lib/python3.13/site-packages/bellows/uart.py", line 108, in reset
async with asyncio_timeout(RESET_TIMEOUT):
File "/usr/local/lib/python3.13/asyncio/timeouts.py", line 116, in __aexit__
raise TimeoutError from exc_val
TimeoutError
File "/usr/src/homeassistant/homeassistant/components/zha/repairs/wrong_silabs_firmware.py", line 87, in probe_silabs_firmware_type
await flasher.probe_app_type()
File "/usr/local/lib/python3.13/site-packages/universal_silabs_flasher/flasher.py", line 244, in probe_app_type
raise RuntimeError("Failed to probe running application type")
RuntimeError: Failed to probe running application type
