I can't update home assistant
I’m trying to update Home assistant (on Hass.io) from 0.100.3 to 0.101.3 version. When I launch the update from the hassio page, the system reboot but the sistem won’t update.
Any errors in the logs? Is your sd card full?
You could also update via the command line if you have ssh setup.
hassio homeassistant update
This is the log
19-11-17 18:40:02 INFO (SyncWorker_1) [hassio.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 1
19-11-17 18:40:02 INFO (SyncWorker_3) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.100.3
19-11-17 18:40:02 INFO (MainThread) [hassio.hassos] Detect HassOS 2.12 on host system
19-11-17 18:40:03 INFO (SyncWorker_2) [hassio.docker.hassos_cli] Found HassOS CLI homeassistant/armv7-hassio-cli with version 14
19-11-17 18:40:04 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/aaa91bdd/zhue/config.json: required key not provided @ data['arch']. Got None
19-11-17 18:40:04 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/aaa91bdd/flicd/config.json: required key not provided @ data['arch']. Got None
19-11-17 18:40:04 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/aaa91bdd/zabbix-agent/config.json: required key not provided @ data['arch']. Got None
19-11-17 18:40:05 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-11-17 18:40:05 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/15ef4d2f repository
19-11-17 18:40:05 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-11-17 18:40:05 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/e680ed44 repository
19-11-17 18:40:05 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/aaa91bdd repository
19-11-17 18:40:05 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/aaa91bdd/zhue/config.json: required key not provided @ data['arch']. Got None
19-11-17 18:40:05 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/aaa91bdd/flicd/config.json: required key not provided @ data['arch']. Got None
19-11-17 18:40:05 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/aaa91bdd/zabbix-agent/config.json: required key not provided @ data['arch']. Got None
19-11-17 18:40:05 INFO (MainThread) [hassio.store] Load add-ons from store: 68 all - 68 new - 0 remove
19-11-17 18:40:05 INFO (MainThread) [hassio.addons] Found 6 installed add-ons
19-11-17 18:40:05 INFO (SyncWorker_5) [hassio.docker.interface] Attach to homeassistant/armv7-addon-configurator with version 3.6
19-11-17 18:40:05 INFO (SyncWorker_6) [hassio.docker.interface] Attach to homeassistant/armv7-addon-mosquitto with version 5.1
19-11-17 18:40:05 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/armv7-addon-ssh with version 6.4
19-11-17 18:40:05 INFO (SyncWorker_0) [hassio.docker.interface] Attach to esphome/esphome-hassio-armv7 with version 1.14.2
19-11-17 18:40:05 INFO (SyncWorker_17) [hassio.docker.interface] Attach to webhookrelay/home-assistant-armhf with version 1.14.2
19-11-17 18:40:05 INFO (SyncWorker_8) [hassio.docker.interface] Attach to hassioaddons/sqlite-web-armv7 with version 2.0.0
19-11-17 18:40:05 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-11-17 18:40:06 INFO (MainThread) [hassio.snapshots] Found 7 snapshot files
19-11-17 18:40:06 INFO (MainThread) [hassio.discovery] Load 1 messages
19-11-17 18:40:06 INFO (MainThread) [hassio.ingress] Load 1 ingress session
19-11-17 18:40:06 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 3
19-11-17 18:40:06 INFO (MainThread) [__main__] Run Hass.io
19-11-17 18:40:06 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-11-17 18:40:06 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-11-17 18:40:06 INFO (MainThread) [hassio.addons] Phase 'system' start 1 add-ons
19-11-17 18:40:06 INFO (SyncWorker_2) [hassio.docker.interface] Clean addon_core_mosquitto application
19-11-17 18:40:11 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-mosquitto with version 5.1
19-11-17 18:40:14 INFO (MainThread) [hassio.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
19-11-17 18:40:16 INFO (MainThread) [hassio.addons] Phase 'services' start 2 add-ons
19-11-17 18:40:16 INFO (SyncWorker_6) [hassio.docker.interface] Clean addon_a0d7b954_sqlite-web application
19-11-17 18:40:16 INFO (SyncWorker_4) [hassio.docker.interface] Clean addon_core_ssh application
19-11-17 18:40:24 INFO (SyncWorker_6) [hassio.docker.addon] Start Docker add-on hassioaddons/sqlite-web-armv7 with version 2.0.0
19-11-17 18:40:24 INFO (SyncWorker_4) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-ssh with version 6.4
19-11-17 18:40:27 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_sqlite-web
19-11-17 18:40:29 INFO (SyncWorker_3) [hassio.docker.interface] Start homeassistant/raspberrypi3-homeassistant
19-11-17 18:40:32 INFO (MainThread) [hassio.api.security] /dns/info access from a0d7b954_sqlite-web
19-11-17 18:42:46 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-11-17 18:42:46 INFO (MainThread) [hassio.addons] Phase 'application' start 3 add-ons
19-11-17 18:42:47 INFO (SyncWorker_17) [hassio.docker.interface] Clean addon_core_configurator application
19-11-17 18:42:47 INFO (SyncWorker_3) [hassio.docker.interface] Clean addon_e680ed44_webhook-relay-remote-access application
19-11-17 18:42:47 INFO (SyncWorker_13) [hassio.docker.interface] Clean addon_15ef4d2f_esphome application
19-11-17 18:42:57 INFO (SyncWorker_3) [hassio.docker.addon] Start Docker add-on webhookrelay/home-assistant-armhf with version 1.14.2
19-11-17 18:42:58 INFO (SyncWorker_17) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-configurator with version 3.6
19-11-17 18:42:58 INFO (SyncWorker_13) [hassio.docker.addon] Start Docker add-on esphome/esphome-hassio-armv7 with version 1.14.2
19-11-17 18:43:02 INFO (MainThread) [hassio.api.security] /host/info access from 15ef4d2f_esphome
19-11-17 18:43:03 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-11-17 18:43:03 INFO (MainThread) [hassio.core] Hass.io is up and running
19-11-17 19:48:23 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.101.3
19-11-17 19:48:23 INFO (SyncWorker_0) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.100.3 to homeassistant/raspberrypi3-homeassistant:0.101.3
19-11-17 19:48:23 INFO (SyncWorker_0) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.101.3.
19-11-17 19:48:25 INFO (SyncWorker_0) [hassio.docker.interface] Stop homeassistant application
19-11-17 19:49:25 INFO (SyncWorker_0) [hassio.docker.interface] Clean homeassistant application
19-11-17 19:49:28 INFO (SyncWorker_19) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.101.3
19-11-17 19:49:48 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-11-17 19:51:48 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-11-17 19:51:53 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-11-17 19:52:49 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-11-17 20:02:52 WARNING (MainThread) [hassio.homeassistant] Don't wait anymore of Home Assistant startup!
19-11-17 20:02:52 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
19-11-17 20:02:52 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.100.3
19-11-17 20:02:52 INFO (SyncWorker_1) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.101.3 to homeassistant/raspberrypi3-homeassistant:0.100.3
19-11-17 20:02:52 INFO (SyncWorker_1) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.100.3.
19-11-17 20:02:54 INFO (SyncWorker_1) [hassio.docker.interface] Stop homeassistant application
19-11-17 20:02:56 INFO (SyncWorker_1) [hassio.docker.interface] Clean homeassistant application
19-11-17 20:02:59 INFO (SyncWorker_15) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.100.3
19-11-17 20:03:19 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-11-17 20:05:25 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-11-17 20:05:30 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-11-17 20:06:15 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-11-17 20:06:30 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-11-17 20:06:30 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.100.3
19-11-17 20:06:30 INFO (SyncWorker_6) [hassio.docker.interface] Cleanup images: ['homeassistant/raspberrypi3-homeassistant:0.101.3']
Now 'm trying to update home assistant from terminal
It shows that you have 7 snapshots on your system. You might make sure those are copied off to your laptop or some other system, and remove them from the Pi.
I’ve tryed to delete the snapshot and the update the system, but nothing. Home assistant won’t update.
Nothing work, I’ve red on the community some discusisons but i can’t find solution.
This is the last update log:
19-11-20 19:17:30 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/hassio-addons/repository repository
19-11-20 19:17:30 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/webhookrelay/home-assistant repository
19-11-20 19:17:30 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/esphome/hassio repository
19-11-20 19:17:30 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
19-11-20 19:17:30 INFO (MainThread) [hassio.store.git] Update add-on https://github.com/pschmitt/hassio-addons repository
19-11-20 19:17:32 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/aaa91bdd/zhue/config.json: required key not provided @ data['arch']. Got None
19-11-20 19:17:32 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/aaa91bdd/zabbix-agent/config.json: required key not provided @ data['arch']. Got None
19-11-20 19:17:32 INFO (MainThread) [hassio.store] Load add-ons from store: 69 all - 0 new - 0 remove
19-11-20 19:57:30 INFO (MainThread) [hassio.host.info] Update local host information
19-11-20 19:57:30 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-11-20 19:57:31 INFO (MainThread) [hassio.host.services] Update service information
19-11-20 19:57:31 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-11-20 19:57:31 INFO (MainThread) [hassio.host.network] Update local network DNS information
19-11-20 19:57:31 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
19-11-20 20:15:04 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-11-20 20:17:30 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-11-20 20:18:04 INFO (SyncWorker_7) [hassio.docker.interface] Restart homeassistant/raspberrypi3-homeassistant
19-11-20 20:20:34 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-11-20 20:25:34 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.101.3
19-11-20 20:25:34 INFO (SyncWorker_0) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.100.3 to homeassistant/raspberrypi3-homeassistant:0.101.3
19-11-20 20:25:34 INFO (SyncWorker_0) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.101.3.
19-11-20 20:25:36 INFO (SyncWorker_0) [hassio.docker.interface] Stop homeassistant application
19-11-20 20:26:37 INFO (SyncWorker_0) [hassio.docker.interface] Clean homeassistant application
19-11-20 20:26:40 INFO (SyncWorker_3) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.101.3
19-11-20 20:27:00 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-11-20 20:29:10 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-11-20 20:29:15 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-11-20 20:30:26 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-11-20 20:40:29 WARNING (MainThread) [hassio.homeassistant] Don't wait anymore of Home Assistant startup!
19-11-20 20:40:29 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
19-11-20 20:40:29 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.100.3
19-11-20 20:40:29 INFO (SyncWorker_3) [hassio.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.101.3 to homeassistant/raspberrypi3-homeassistant:0.100.3
19-11-20 20:40:29 INFO (SyncWorker_3) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.100.3.
19-11-20 20:40:31 INFO (SyncWorker_3) [hassio.docker.interface] Stop homeassistant application
19-11-20 20:40:35 INFO (SyncWorker_3) [hassio.docker.interface] Clean homeassistant application
19-11-20 20:40:38 INFO (SyncWorker_16) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.100.3
19-11-20 20:40:58 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-11-20 20:43:03 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-11-20 20:43:08 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-11-20 20:43:59 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-11-20 20:44:39 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-11-20 20:44:39 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.100.3
19-11-20 20:44:39 INFO (SyncWorker_1) [hassio.docker.interface] Cleanup images: ['homeassistant/raspberrypi3-homeassistant:0.101.3']
Someone can help me please?
Same problem here, update form 0.100.2 to 0.102.0 does not work…
I dont have the APi password as i removed it long time ago.
But my errors just tells me nothing. Kinda irritating…
19-12-01 08:07:53 ERROR (SyncWorker_36) [hassio.docker.interface] Can’t install homeassistant/qemux86-64-homeassistant:0.102.3 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on [MYIP]:53: read udp [MYIP]:57184->[MYIP]:53: read: connection refused”).
19-12-01 08:07:53 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
Looks really odd. Port 53 is DNS. Is something blocking DNS?
Sounds like he might be using pihole add-on?
Thx for the input. The problem was that Hassio DIF mot like the Mac i was Ussing for my vm. And that made the problem start. Changed Mac adress and now its all good.
Thx for the dns input, that made me rethink What the problem was.
