I apologize to everyone because I am a beginner with NodeRed. I would like to create a very simple automation that turns on a light at a certain time of day.
I created the flow, the only problem I can’t see the lamp to be turned on is connected to a shelly 1 and integrated on HA via mqtt.
The entity is configured and working is called: light.lampada_ground_sala, but on Node Red it does not appear …
So you have a Shelly 1 and it’s connected to a dumb lamp as a relay.
Have you made a light template to create the light entity?
Can we see that config?
Do you have a switch.shelly1? Does that exist in node red?
