Hellow there…
I don’t care !!! Seriously. My fritz box at 172.30.47.1 has been removed from the network. Why the hell is it still trying to connect, why does it still discover it, and most of all, why can’t I delete it ?
Obviously, I have checked configuration.yaml and there is nothing there about fritz. Logs just tell that it times out (which make sense, come on) So I’m out of option. Does any one have any idea where I can look ?
2023-02-12 00:48:50.457 WARNING (MainThread) [homeassistant.config_entries] Config entry 'InternetGatewayDeviceV2 - FRITZ!Box 7490' for upnp integration not ready yet: Device not discovered: uuid:75802409-bccb-40e7-9f6c-5C49793E4739::urn:schemas-upnp-org:device:InternetGatewayDevice:2; Retrying in background
2023-02-12 00:49:38.741 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: motion_blinds, fritz
2023-02-12 00:49:40.743 ERROR (SyncWorker_2) [fritzconnection] Unable to get a connection: HTTPConnectionPool(host='172.30.47.1', port=49000): Max retries exceeded with url: /igddesc.xml (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f3ccb0659c0>, 'Connection to 172.30.47.1 timed out. (connect timeout=60.0)'))
2023-02-12 00:49:40.754 WARNING (MainThread) [homeassistant.config_entries] Config entry 'FRITZ!Box 7490' for fritz integration could not authenticate: Unable to get a connection: HTTPConnectionPool(host='172.30.47.1', port=49000): Max retries exceeded with url: /igddesc.xml (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f3ccb0659c0>, 'Connection to 172.30.47.1 timed out. (connect timeout=60.0)'))
2023-02-12 01:09:35.032 ERROR (SyncWorker_5) [fritzconnection] Unable to get a connection: HTTPConnectionPool(host='172.30.47.1', port=49000): Max retries exceeded with url: /igddesc.xml (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f3cb5814250>, 'Connection to 172.30.47.1 timed out. (connect timeout=60.0)'))
