I’m using a raspberry 3b and suddenly I can’t use it normally.
Most integrated components are not loaded.
Components check and does not be restarted and restart.
Is it because of this log?
Logger: homeassistant.config_entries
Source: requirements.py:248
First occurred: 오후 10:20:41 (1 occurrences)
Last logged: 오후 10:20:41
Error setting up entry Raspberry Pi for raspberry_pi
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 388, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/raspberry_pi/init.py”, line 22, in async_setup_entry
await hass.config_entries.flow.async_init(
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 847, in async_init
flow, result = await task
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 865, in _async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 967, in async_create_flow
await _load_integration(self.hass, handler_key, self._hass_config)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 2034, in _load_integration
await async_process_deps_reqs(hass, hass_config, integration)
File “/usr/src/homeassistant/homeassistant/setup.py”, line 420, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 52, in async_get_integration_with_requirements
return await manager.async_get_integration_with_requirements(domain)
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 171, in async_get_integration_with_requirements
await self._async_process_integration(integration, done)
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 186, in _async_process_integration
await self.async_process_requirements(
File “/usr/src/homeassistant/homeassistant/requirements.py”, line 248, in async_process_requirements
async with self.pip_lock:
File “/usr/local/lib/python3.11/asyncio/locks.py”, line 15, in aenter
await self.acquire()
File “/usr/local/lib/python3.11/asyncio/locks.py”, line 114, in acquire
await fut
asyncio.exceptions.CancelledError: Global task timeout
