In researching my own issue, I’ve seen several different topics and posts regarding similar devices.
Problem: I could not for the life of me connect my Govee Ambient TV light strip to home assistant via matter. I could with the Govee add on and I could with the Govee-to-MQTT add on.
I would hold power while pressing middle button 4 times to reset things, then try again. I would get the same unable to connect to device error.
somewhere in the process of adding and removing the lights to the Govee app I realized that there was a step I may have been neglecting.
Here is an out line of the steps I used to successfully connect my Govee lights to Home Assistant via Matter.
remove the light from your govee app
hold down power button while pressing middle button 4 times.
there will be a short “light show” but now your lights will be in discovery mode.
Add the device back into the Govee app.
4.5) Go into the Govee settings for that light and under the Matter section, copy the QR code to a secondary device so you can use your primary device to scan the QR code off of the secondary device.
Complete the rest of the set up in the Govee app including the WiFi connection settings. It is worth noting here you must have IPv6 enabled on your router and your home assistant, mobile device, and govee device must be able to obtain an IPv6 address. Complete the Govee light set up in full!
once your device is registered and showing up as connected via WiFi in the Govee app and not just bluetooth, we are ready for the next step.
Compete these steps from your mobile device using the home assistant companion app.
go to Settings → Devices and Services
click on “Add Integration”
click on Matter (this is assuming you have the matter server already installed. Please install it if you have not done so already.)
Click “no its new”.
you should be brought to a screen where you are prompter to scan a QR code or enter a code. Scan the QR code you copied in step 4.
When you are at the “Get Ready for Set Up” screen THIS IS THE KEY STEP!!! before you press next, do a quick short press of the power button on the Govee device. In my case it appeared to have turned the device off, but the red indicator light remained on.
Hit next in the home assistant app. It will find device, generate matter credentials and add to home assistant.
Instead of device not found, I was greeted with a device added message.
It seems that while holding power and pressing middle button 4 times does in fact reset the device and put it into a “discovery mode” you must push the power button again one more quick time just before actually pairing it with Home Assistant in order to enter it into “pairing mode” and let it successfully connect. Otherwise, you will scan the QR or enter the matter code, it will search, it will generate matter credentials, it will check connectivity with WiFi and it will fail.
TLDR
-make sure IPv6 is enabled on your network.
-connect your lights to wifi via the govee app
-do a reset on them (hold power, press middle button 4 times, prepare for light show)
-prepare to pair them from the home assistant companion app in the add integration → matter device section.
-press power button once more.
-initiate integration process.
-device is added via matter
I hope this helps other people out there, I know I spent a few days researching and testing different ways to get this to work. My goal is to avoid using APIs for all my devices. I deleted any Govee integrations after setting this up and was still allowed full control of my Govee device.
same for me. trying to get this one to matter (my situation even worse - I run HA in container) Govee Net Lights – LED Net Lights for Bushes & Outdoor Decor | Govee EU It sees the device but fails to pair (also zero messages in ha and matter container logs). BTW I somehow managed to get T3 backlight into it. Now it brews me cappuchino!
You are my hero Nearly ten years later i run into the same issue. Took me hours and hours to add my govee light strip to add to matter again after i must change the WLAN. Thanks to your post i could add the govee to my IoT Asus network and add also to matter in home assistant.
Thanks again, you made my day.
I have a similar issue with another Govee lamp (Celiling Light Pro, H60A6) and I’m unable to connect the lamp with HA via Matter. There are no buttons on the lamp that I could press, so I cannot execute steps 2 and 13 from your list. Instead of step 2 I tried a “network reset” from the Govee app as this is also the recommendation from the Matter documentation in the Govee app. Instead of step 13, I tried to power off (i.e., complete power cut, not only software power off) and on again. But nothing helped, I always get the error that connection is not possible. IPv6 is enabled in my network, so this shouldn’t be the issue. Any ideas?
Just wanted to say a big thanks, as I was struggling to get these added to HA,
I have the Govee TV Backlight 3 lite (H6099)
This worked a treat, though I did not need to do…
“1. When you are at the “Get Ready for Set Up” screen THIS IS THE KEY STEP!!! before you press next, do a quick short press of the power button on the Govee device. In my case it appeared to have turned the device off, but the red indicator light remained on.”
HA Matter found it straight away and is working fine.
Anyone have any experience with the Govee Christmas Sparkle String lights?
Just bought these and tried adding them via the Matter integration with no luck whatsoever. Removed them from the Govee app and reset them multiple times now. Tried to follow what OP posted but these string lights don’t exactly seem to work that way.
Weirdly, I was able to add them in Apple Home app first try.
I hoped this might help add them in HA since during setup there’s an option to add accessories already paired to a controller. So tried using that flow but get an error again.
I have a shelly outdoor plug with Matter that I added to HA first try…
So I’m hoping there’s some trick to getting these added but I’m at a loss right now…
I have an IOT network that does not have internet access where home assistant and all of my IOT devices live. The Govee app does not like this at all. Even for matter pairing which is supposed to be completely local (I thought). I had to first create a fixed IP address for the Govee light. Then created an ACL rule that allowed both my phone (used for pairing) and the Govee light access to the internet temporarily. Only then could I get all the way through the Matter pairing process. This worked for the Uplifter (H60B0) and outdoor string lights (H7025). They are currently functional in HA without internet access.
However, I still cannot for the life of me get the Table Lamp 2 (HS6022) to connect to Matter.
In case it’s useful, I started on this journey because the Govee Lights Local integration just stopped working after I swapped out some networking infrastructure (router & switch). All the devices show up in HA, HA thinks they can be controlled, but nothing happens. Maybe it’s that the Govee lights realized they don’t have internet access when they got kicked off during the temporary downtime.
I had the same problem with a Govee RGBWW Led bulb; without buttons. Thanks to this post I tried suggested steps but didn't work at first.
In my case steps to get success were (after several tries):
H6008 series bulb:
0 - If you linked the bulb in Google Home (or other assistant), unlink it by using option of linking, and unlink account, in that app.
1 - Remove device from Govee app.
2 - Hold switched on the bulb at least 5 seconds, (Switch off one second, Switch On) x4 times.
3 - Light flashes.
4 - Add device into Govee app again.
4.1 - Add wifi (perhaps it's better SKIP this step; see 4.3)
4.2 - Take note of QR code in Matter section.
4.3 - Do "Network Reset".
5 - Use mobile app Home Assistant Companion app.
6 - Go Settings → Devices and Services.
7 - Click on "Add integration".
8 - Click on "Add Matter device".
9 - Click on "No. It's new" option.
10. - Use QR code saved on step 4.2
11 - Now, when screen "Get ready for Set up" is shown, switch off very shortly and switch on bulb. If light of bulb doesn't get off (although you switched on) repeat until that situation occurs and quickly click next button to see if finds device and register on Home Assistant.
If there is no luck retry repeating from step 10 or so, it could work.
