I found some extra RF codes for my Harbor Breeze Saratoga Ceiling Fan
I recently got a Bond Bridge to control my L1902 Harbor Breeze Saratoga Ceiling Fan. Remote has FCC ID A25-Tx007R1.
After Bond learned one button from the remote, it offered me some choices. It was template L2 that worked for me, its buttons exactly matched my remote, 3 speeds, off, toggle, and a button to cycle the dimmer.
Unfortunately, I had in my head that I would be able to control the dimmer up and down, and had already bought some Zen32 scene controllers with that in mind. (I want to use buttons 1-3 as brightness up and down, and 2-4 as speed up and down.) “Toggle” instead of “On” and “Off” isn’t always ideal either for automations, although that does make sense for the big button on the Zen32.
I used the Bond local REST API to download the codes for the 6 buttons. And I used the Bond cli to send signals to test with.
Looking through the signals, I noticed that only 4 bits were changing. They were each separated by “10”, so “x10x10x10x10”.
So I threw together a shell script to let me test different bits.
#!/bin/zsh
bit1=0
bit2=0
bit3=0
bit4=0
data1="10010010010010010010010010010010010010010010010010"
data2="${bit1}10${bit2}10${bit3}10${bit4}10"
data3="110010110010000000000000000000000000000"
data=$data1$data2$data3
bond signal --freq 314994 --bps 2250 --reps 10 --modulation OOK --encoding cq --data "$data"
As I was hoped, I actually found some extra commands!
  • 0000: Light off
  • 0100: Dimmer brightness decrease
  • 1000: Dimmer brightness cycle
  • 1100: Dimmer brightness increase
(For some reason in my notes, I had that 1100 came from Bond as the brightness cycle, but when I tested it was only increase and 1000 is cycle. Either way, I found what I was looking for.)
One thing I was still missing is “light on”. (As opposed to light toggle.)
I never found a command that just did that, but I realized that the dimmer commands also function as “light on”. So I effectively have that now too!
I still need to figure out how to load these new commands into Bond. Since it’s using a template, the app only lets me hide buttons, not add new ones. But I think I should be able to add them from the REST API. I will try that soon.
Hopefully this helps someone else. I would guess that many devices have a few extra codes beyond what the remote has, but I don’t know how common it is. Doesn’t hurt to poke around and try!
One other thing: when I was playing around with the other template for similar fan models, I believe I found some buttons to jump the brightness up or down. I still need to go back and get those codes out of Bond and see what they were. Perhaps there’s more bits that can be changed.
Did you ever figure out how to add these custom buttons via the REST API? I have the same fan and am looking to do the same.
For anyone that comes across this I made some progress with this but it’s a little messy. Some more details at Custom or discoverable templates for fan with directional dimming RF codes - Fans - Bond Home Forum if it’s helpful
