I get error by startup HA after login (Record not found)
I get this error, i have nothing changed about that but what is it, what does it?
Looks like a corrupt database. What errors do you get in the log?
Most of the time the easiest solution is to delete the db by shuting down Home Assistant, deleting home-assistant_v2.db, starting home assistant again.
So when you checked the log, what did it say?
I have installed HASSio on Proxbox. How can i delete that when the VM is powered off? Should that be then create i working DB?
You don’t need to power off the VM, only shutdown Home Assistant. I’m not even sure if you need to shutdown first before deleting.
Anyway, what did the logs say under Configuration -> Logs? Could also be another issue.
Ok, .DB deleted and restarted problem solved. OLD db was 350MB and the new one is now 300KB.
I see this logs now;
Logger: coap
Source: /usr/local/lib/python3.8/site-packages/aiocoap/transports/udp6.py:391
First occurred: 12:41:02 PM (2 occurrences)
Last logged: 12:41:18 PM
Connection loss was not expected.
