I have lost my whole home assistant
i have reinstalled ubuntu 24.04.1 today and restored it with Duplicati, when I restore it and start the home assistant container. I can no longer login when i try to reset my password i shows no user found
Have you pointed the container to the correct config-folder and that contains the old data?
yes all pointed
And you have verified that the data is the old data, not newly generated data from HA?
After all is said and done and you cannot access it, then possiblu start over and restore from a different backup. Also, once up in running be saure to test your backups as well
yep backup had permissions errors for a whole year restarting all over :frowning:
