I have problem vid installing
File editor, add ons, terminal, doesnt install proberly. I have to go by hassio.
I have done factory reset several times but the same isue is coming back.
I have Nokia Fast Mile 5G .
Your problem is not clear in your question.
What hardware are you running? You told us about your internet hardware, but not what computer you have, what version of Home Assistant you are trying to load. or what you have tried so far. How to help us help you - or How to ask a good question
Sorry. I have à HA. Green. I ment that maybe that some issue perhaps was in Nokia maybe dubbel NAT or something. My issue is that i cant se addons the terminal and a few more. I have to go to webui hassio I also got many issue in the log The supervisor dont talk to the frontend perhaps.
Ive got this after flashing SD and a new factory reset
Login attempt or request with invalid authentication from supervisor (172.30.32.2). See the log for details.
Hi, you still haven’t shared much to help you and you even seem to not have clicked the link that my fellow supporter has provided and there are no logs to be seen…
You’re not making it easy to help you.
I am sorry that I didnt follow the rules. I am frustrated. My goal is that I will have me HomeAssistant to work properly but this has failed everytime that I have tried.
My first trial was with VM on a Synology.
My second was that I bougt a HA green and installed HA OS
After that so have I done several factory reset and always I got the same issue.
The terminal, the file editor is hidden. Command c doesnt work.
Because of that my HA will not install properly what ever I try, all the same,
I must have a common denominator and that is my network. I have a Nokia Fast Mile 5G and Ive been tols that it coud be some issue with that when you install HA.
No problem; you don’t have to follow any rules.
We are trying to help you and that sentence/link that @Sir_Goodenough has posted says it all: “help us to help you”.
I do understand that one can get frustrated, been there too.
Just try to provide us some information and respond to us as direct as possible.
How come you have double NAT and can’t you put everything in 1 logical network (subnet)?
I dont know for shure that I have dubbel NAT but I have got that for suggestion. I have Nokia Fast Mile as a active anntenna with SIM and a router after that without. I am not shure att all for anything but because I have tried several methods without sucess so do I think that it has something with network to do.
Ive got this after I did a factory reset with SD
2026-04-11 15:08:42.415 ERROR (MainThread) [supervisor.homeassistant.api] Can’t update Home Assistant access token!
Loggare: py.warnings
Källa: components/image/init.py:16
Inträffade först: 15:08:52 (1 förekomst)
Senast loggat: 15:08:52
/usr/local/lib/python3.14/site-packages/rich/segment.py:547: SyntaxWarning: ‘return’ in a ‘finally’ block return
Loggare: homeassistant.components.http.ban
Källa: components/http/ban.py:140
integration: HTTP (dokumentation, ärenden)
Inträffade först: 15:08:42 (1 förekomst)
Senast loggat: 15:08:42
Login attempt or request with invalid authentication from supervisor (172.30.32.2). Requested URL: ‘/auth/token’. (HomeAssistantSupervisor/2026.03.3 aiohttp/3.13.4 Python/3.14)
The first in supervisor log the second and third in core log
Thank you very much everybody. I have no issues anymore.
Good it got fixed.
Can you at least share with the community what caused your issue and how it got solved?
One of the issue wasnt a issue. Ive tried to get add/ons. It wouldnt apper how I tried. Then I figured out that in ver 26 it is called APPS And that problem was solved. Then it run better and better and I even did some changes in network I deleted my own DNS and wrote googles 8.8.8.8. 8.8.4.4 I anaktivated IP 6
