I have this ESP Plug with Tasmota
I bought a very simple plug that could be flashed with Tasmota because it comes with an ESP board, but now I was thinking if it could be possible to be flashed into ESPHome from Tasmota.
I cannot find any docs in the ESPHome regarding this plug, but I’ve seen a ton of places where I can clearly see this plug in ESPHome (it’s kind of a white label plug with 100000 brands behind).
Any ideas?
I saw this guy
Using a YAML template with the ESP Home addon and generating a firmware to be flashed through Tasmota firmware upgrade page. Maybe I should be looking for a plug template for something similar.
Often the answer is “its Tuya”.
But you may have a match here?
As to whether it still has a ESPHome compatible chip and can be tuya-converted…well that’s getting less likely…
After opening it, I found it’s a BEKEN chip, so I have flashed an OpenBK firmware.
Now I’m trying to understand the GPIO to make it fully work (now it works only as a relay with default conf)
Bright side, is that it’s not cloud anymore
