When starting out I created a second dashboard to help me learn. The primary dashboard now has nothing in it. Can I replace the lovelace file with the second dashboard file in /config/.storage? Is this the correct way to do it? Any direction appreciated.
Make the one you want to keep the default dashboard, you can do this through the UI top right settings menu I believe. Once the one you want to keep is made the default, then you have the option in the menu to delete the other one. I’d backup your keeper just in case. I hope this helps - I just did this recently. Couldn’t figure out why they’re wasn’t a delete button until I realized it won’t let you delete the default.
reread your note and now I understand. Still very early here and brain is not functioning as well as I would like. I need to delete the default so that is why I was looking at moving files around.
