I installed hass-aarlo and lovelace hass arlo thru HACS. Most of it works but can't play library clips, only audio plays with still image
Using card type picture:entity it will play the last clip, in fast forward mode.
But using card type custom:aarlo-glance, I can select a clip but won’t play the video, only audio.
Is there a config I am missing or is this a bug?
My installation is on mac os x in python virtual env.
I don’t see any arlo (or aarlo) items in HACS, so where precisely did you get them?
Oops I got that wrong. They are both there, my interaction with HACS is in error.
What errors are you seeing? Logs?
Nothing in the logs. Basically using the aarlo-glance card type, I can click and see a gallery of clips. When I click to play, I hear audio but no video, just a still image.
As these aren’t home-assistant native integrations or lovelace cards I suggest you post an issue on the author’s github.
Good point… thanks!
