I just installed the addon, and the webui doesn't load
All I see is this in the logs every second:
ERROR 'log' directive deprecated, please convert to new 'logs' syntax
[08:04:53] INFO: Starting AppDaemon...
[08:04:54] INFO: Starting AppDaemon...
[08:04:55] INFO: Starting AppDaemon...
[08:04:56] INFO: Starting AppDaemon...
[08:04:57] INFO: Starting AppDaemon...
It looks like the webui isn’t even started. Any ideas as to what I need to do?
I got the answer on discord in case anyone else runs into the issue. I must have installed the old AppDaemon 3 at some point a while ago and the config files were still there. I just deleted them and started from scratch. You an also follow the “Upgrading from AppDaemon 3 doc” if you have settings in there you want to keep.
