I just want today's high temp
I’m trying to get “today’s high temp”. I was hoping this would be easy, but it seems to be tricky for two reasons:
  • Accuweather seems to only want to give me “RealFeel” numbers which are not just temps, they are adjusted for humidity and such. I am looking for the actual real, what would be measured by a thermometer, temp.
  • It also seems to give numbers “For the next 24h period” not “today”.
Any advice on how to just get today’s forecasted high?
The weather entity should have high/low for the day in the forecasts.
Then I must be missing something obvious. How can I access it? If my entity is called weather.foo, what can I put into my yaml template to get it?
You need to call the forecasts service and read the response. Gave it a quick shot for you since I’m also using accuweather, and temperature matches the high for today.
Request:
service: weather.get_forecasts
  type: daily
  entity_id: weather.home_2
Response (truncated)
weather.home_2:
  forecast:
    - datetime: "2024-08-11T05:00:00+00:00"
      cloud_coverage: 0
      precipitation_probability: 0
      uv_index: 10
      wind_bearing: 315
      condition: sunny
      temperature: 33.8
      apparent_temperature: 39.8
      templow: 25.1
      wind_gust_speed: 22.2
      wind_speed: 9.3
      precipitation: 0
      humidity: 54
    - datetime: "2024-08-12
temperature and templow match today’s forecast as shown in the more info in my weather card for today
Thanks, this is exactly what I needed.
Using this,I ended up making a template with a bunch of sensors in it to expose the info for today and tomorrow. This lets me use these values in automations (e.g., keep the blinds closed all day if the high is greater than X° etc… )
Thanks!
template:
  - trigger:
      - platform: time_pattern
        hours: /1
      - platform: homeassistant
        event: start
      - platform: event
        event_type: event_template_reloaded
      - action: weather.get_forecasts
          type: daily
        response_variable: daily
      - name: Forecast Today Condition
        unique_id: forecast_today_condition
        state: "{{ daily['weather.home'].forecast[0].condition }}"
        icon: mdi:weather-partly-rainy
      - name: Forecast Today Temperature
        unique_id: forecast_today_temperature
        state: "{{ daily['weather.home'].forecast[0].temperature }}"
        unit_of_measurement: °F
        device_class: temperature
      - name: Forecast Today Low Temperature
        unique_id: forecast_today_templow
        state: "{{ daily['weather.home'].forecast[0].templow }}"
      - name: Forecast Today Apparent Temperature
        unique_id: forecast_today_high_apparent_temperature
        state: "{{ daily['weather.home'].forecast[0].apparent_temperature }}"
      - name: Forecast Today Humidity
        unique_id: forecast_today_humidity
        state: "{{ daily['weather.home'].forecast[0].humidity }}"
        unit_of_measurement: '%'
        device_class: humidity
      - name: Forecast Today Cloud Cover
        unique_id: forecast_today_cloud_cover
        state: "{{ daily['weather.home'].forecast[0].cloud_coverage }}"
        icon: mdi:cloud
      - name: Forecast Today Precipitation Probability
        unique_id: forecast_today_precipitation_probability
        state: "{{ daily['weather.home'].forecast[0].precipitation_probability }}"
        icon: mdi:water-percent
        state: "{{ daily['weather.home'].forecast[0].precipitation }}"
        unit_of_measurement: in
        icon: mdi:water
      - name: Forecast Today UV Index
        unique_id: forecast_today_uv_index
        state: "{{ daily['weather.home'].forecast[0].uv_index }}"
        unit_of_measurement: 'UV index'
        icon: mdi:sun-wireless
      - name: Forecast Today Wind Bearing
        unique_id: forecast_today_wind_bearing
        state: "{{ daily['weather.home'].forecast[0].wind_bearing }}"
        icon: mdi:compass
      - name: Forecast Today Wind Speed
        unique_id: forecast_today_wind_speed
        state: "{{ daily['weather.home'].forecast[0].wind_speed }}"
        unit_of_measurement: mph
        icon: mdi:weather-windy
      - name: Forecast Today Wind Gust Speed
        unique_id: forecast_today_wind_gust_speed
        state: "{{ daily['weather.home'].forecast[0].wind_gust_speed }}"
      - name: Forecast Tomorrow Condition
        unique_id: forecast_tomorrow_condition
        state: "{{ daily['weather.home'].forecast[1].condition }}"
      - name: Forecast Tomorrow Temperature
        unique_id: forecast_tomorrow_temperature
        state: "{{ daily['weather.home'].forecast[1].temperature }}"
      - name: Forecast Tomorrow Low Temperature
        unique_id: forecast_tomorrow_templow
        state: "{{ daily['weather.home'].forecast[1].templow }}"
      - name: Forecast Tomorrow Apparent Temperature
        unique_id: forecast_tomorrow_high_apparent_temperature
        state: "{{ daily['weather.home'].forecast[1].apparent_temperature }}"
      - name: Forecast Tomorrow Humidity
        unique_id: forecast_tomorrow_humidity
        state: "{{ daily['weather.home'].forecast[1].humidity }}"
      - name: Forecast Tomorrow Cloud Cover
        unique_id: forecast_tomorrow_cloud_cover
        state: "{{ daily['weather.home'].forecast[1].cloud_coverage }}"
        icon: mdi:cloud
      - name: Forecast Tomorrow Precipitation Probability
        unique_id: forecast_tomorrow_precipitation_probability
        state: "{{ daily['weather.home'].forecast[1].precipitation_probability }}"
        state: "{{ daily['weather.home'].forecast[1].precipitation }}"
        icon: mdi:water
      - name: Forecast Tomorrow UV Index
        unique_id: forecast_tomorrow_uv_index
        state: "{{ daily['weather.home'].forecast[1].uv_index }}"
      - name: Forecast Tomorrow Wind Bearing
        unique_id: forecast_tomorrow_wind_bearing
        state: "{{ daily['weather.home'].forecast[1].wind_bearing }}"
        icon: mdi:compass
      - name: Forecast Tomorrow Wind Speed
        unique_id: forecast_tomorrow_wind_speed
        state: "{{ daily['weather.home'].forecast[1].wind_speed }}"
      - name: Forecast Tomorrow Wind Gust Speed
        unique_id: forecast_tomorrow_wind_gust_speed
        state: "{{ daily['weather.home'].forecast[1].wind_gust_speed }}"
I’m far from being an expert, but won’t that always show the icon as partly rainy?
If this is what you intended, then great. If not, you might run into the situation where it’s sunny and the icon will be incorrect.
(PS - before you ask, I have no idea how to return the correct icon depending on weather. I would just remove it and pray it handles it by itself)
has anyone got anything beyond today and tommorow to work? state: “{{ daily[‘weather.home’].forecast[0].temperature }}”, and state: “{{ daily[‘weather.home’].forecast[1].temperature }}” works for me, buyt state: “{{ daily[‘weather.home’].forecast[2].temperature }}” as well as 3,4,5 do not work?
I ran into the same problem, found a few cryptic references, but this is a very clear, complete, and helpful “recipe.” Thanks for sharing!
