I Keep breaking the frontend
Hi all
I keep having a recurring problem that I’m having to solve with a reflash. What i’m doing is adding the custom hue sensor under custom_components/sensor/hue.py and adding it to the configuration page. That will normally work fine, and I add the discovered cast devices and can restart fine, eventually I’ll get to a point where i’ll restart where the frontend won’t load again displaying:
This site can’t be reached
hassio.local refused to connect.
Search Google for hassio local 8123
ERR_CONNECTION_REFUSED
My configuration is below:
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 0
  longitude: 0
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  time_zone: UTC
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Secrets are defined in the file secrets.yaml
  # api_password: !secret http_password
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  # base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
  - platform: yr
  - platform: hue
    ip_address: 192.168.1.120
    token: dwXXXXXXXXXXXXXXXXXXXXXXXXV
# Text to speech
tts:
  - platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
My logs below:
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.script>
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.loader] Loaded config.automation from homeassistant.components.config.automation
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.automation>
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.loader] Loaded config.core from homeassistant.components.config.core
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.core>
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.loader] Loaded config.hassbian from homeassistant.components.config.hassbian
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.loader] Loaded config.group from homeassistant.components.config.group
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.group>
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.loader] Loaded config.customize from homeassistant.components.config.customize
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.customize>
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.3 seconds.
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logbook>
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.entity_registry>
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.downstairs_bedroom_switch, old_state=None, new_state=<state sensor.downstairs_bedroom_switch=2_hold_up; last_updated=['2018-07-05', '07:35:43'], battery=100, on=True, reachable=True, friendly_name=Downstairs Bedroom switch, icon=mdi:remote @ 2018-07-10T11:01:22.966677+00:00>>
2018-07-10 11:01:22 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.upstairsswitch, old_state=None, new_state=<state sensor.upstairsswitch=3_click_up; last_updated=['2018-07-10', '10:57:13'], battery=100, on=True, reachable=True, friendly_name=UpstairsSwitch, icon=mdi:remote @ 2018-07-10T11:01:22.972075+00:00>>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.downstairs_outside_switch, old_state=None, new_state=<state sensor.downstairs_outside_switch=4_click_up; last_updated=['2018-07-09', '23:08:58'], battery=100, on=True, reachable=True, friendly_name=Downstairs Outside switch, icon=mdi:remote @ 2018-07-10T11:01:23.000528+00:00>>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=automation.volume_down, old_state=None, new_state=<state automation.volume_down=off; last_triggered=2018-07-10T10:57:13.582439+00:00, id=1531127243955, friendly_name=Volume down @ 2018-07-10T11:01:23.034018+00:00>>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=automation.light_off, old_state=None, new_state=<state automation.light_off=off; last_triggered=None, id=1531127811279, friendly_name=Light Off @ 2018-07-10T11:01:23.036608+00:00>>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=automation.light_on, old_state=None, new_state=<state automation.light_on=off; last_triggered=None, id=1531127759814, friendly_name=Light On @ 2018-07-10T11:01:23.039258+00:00>>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=automation.volume_up, old_state=None, new_state=<state automation.volume_up=off; last_triggered=2018-07-10T10:56:39.594149+00:00, id=1531127362859, friendly_name=Volume up @ 2018-07-10T11:01:23.044573+00:00>>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=trigger>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=reload>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=toggle>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=turn_on>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=automation, service=turn_off>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.3 seconds.
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=automation>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=group, service=set, service_data=object_id=all_automations, name=all automations, entities=['automation.light_off', 'automation.light_on', 'automation.volume_down', 'automation.volume_up'], visible=False, service_call_id=1973312464-2>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_automations, old_state=None, new_state=<state group.all_automations=off; entity_id=('automation.light_off', 'automation.light_on', 'automation.volume_down', 'automation.volume_up'), order=0, auto=True, friendly_name=all automations, hidden=True @ 2018-07-10T11:01:23.065776+00:00>>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1973312464-2>
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.setup] Setting up discovery
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.1 seconds.
2018-07-10 11:01:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery>
2018-07-10 11:01:25 INFO (MainThread) [homeassistant.setup] Setting up updater
2018-07-10 11:01:25 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2018-07-10 11:01:25 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.setup] Setting up cast
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.setup] Setup of domain cast took 0.0 seconds.
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=cast>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.setup] Setting up media_player
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_on>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_off>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=toggle>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_up>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_down>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play_pause>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_pause>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_stop>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_next_track>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_previous_track>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=clear_playlist>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_set>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_mute>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=media_seek>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=select_source>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=select_sound_mode>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=play_media>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=media_player, service=shuffle_set>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 0.1 seconds.
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=media_player>
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.loader] Loaded media_player.cast from homeassistant.components.media_player.cast
2018-07-10 11:01:27 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.cast
2018-07-10 11:01:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.downstairs_bedroom_tv, old_state=None, new_state=<state media_player.downstairs_bedroom_tv=unavailable; friendly_name=Downstairs Bedroom TV, supported_features=21437 @ 2018-07-10T11:01:28.691623+00:00>>
2018-07-10 11:01:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.downstairs_outside, old_state=None, new_state=<state media_player.downstairs_outside=unavailable; friendly_name=Downstairs Outside, supported_features=21437 @ 2018-07-10T11:01:28.711943+00:00>>
2018-07-10 11:01:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.downstairs_all, old_state=None, new_state=<state media_player.downstairs_all=unavailable; friendly_name=Downstairs All, supported_features=21437 @ 2018-07-10T11:01:28.715798+00:00>>
2018-07-10 11:01:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.downstairs_bedroom, old_state=None, new_state=<state media_player.downstairs_bedroom=unavailable; friendly_name=Downstairs Bedroom, supported_features=21437 @ 2018-07-10T11:01:28.718856+00:00>>
2018-07-10 11:01:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.demo, old_state=None, new_state=<state media_player.demo=unavailable; friendly_name=Demo, supported_features=21437 @ 2018-07-10T11:01:28.728284+00:00>>
2018-07-10 11:01:28 INFO (SyncWorker_11) [pychromecast] Querying device status
2018-07-10 11:01:28 INFO (SyncWorker_12) [pychromecast] Querying device status
2018-07-10 11:01:28 INFO (SyncWorker_5) [pychromecast] Querying device status
2018-07-10 11:01:28 INFO (SyncWorker_6) [pychromecast] Querying device status
2018-07-10 11:01:28 INFO (SyncWorker_2) [pychromecast] Querying device status
2018-07-10 11:01:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.downstairs_bedroom_tv, old_state=<state media_player.downstairs_bedroom_tv=unavailable; friendly_name=Downstairs Bedroom TV, supported_features=21437 @ 2018-07-10T11:01:28.691623+00:00>, new_state=<state media_player.downstairs_bedroom_tv=off; friendly_name=Downstairs Bedroom TV, supported_features=21437 @ 2018-07-10T11:01:28.918737+00:00>>
2018-07-10 11:01:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.downstairs_bedroom, old_state=<state media_player.downstairs_bedroom=unavailable; friendly_name=Downstairs Bedroom, supported_features=21437 @ 2018-07-10T11:01:28.718856+00:00>, new_state=<state media_player.downstairs_bedroom=off; friendly_name=Downstairs Bedroom, supported_features=21437 @ 2018-07-10T11:01:28.923462+00:00>>
2018-07-10 11:01:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.downstairs_outside, old_state=<state media_player.downstairs_outside=unavailable; friendly_name=Downstairs Outside, supported_features=21437 @ 2018-07-10T11:01:28.711943+00:00>, new_state=<state media_player.downstairs_outside=off; friendly_name=Downstairs Outside, supported_features=21437 @ 2018-07-10T11:01:28.960347+00:00>>
2018-07-10 11:01:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.downstairs_all, old_state=<state media_player.downstairs_all=unavailable; friendly_name=Downstairs All, supported_features=21437 @ 2018-07-10T11:01:28.715798+00:00>, new_state=<state media_player.downstairs_all=off; friendly_name=Downstairs All, supported_features=21437 @ 2018-07-10T11:01:28.989275+00:00>>
2018-07-10 11:01:29 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.foxtel_4022, old_state=None, new_state=<state media_player.foxtel_4022=unavailable; friendly_name=Foxtel 4022, supported_features=21437 @ 2018-07-10T11:01:29.190616+00:00>>
2018-07-10 11:01:29 INFO (SyncWorker_13) [pychromecast] Querying device status
2018-07-10 11:01:29 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.foxtel_4022, old_state=<state media_player.foxtel_4022=unavailable; friendly_name=Foxtel 4022, supported_features=21437 @ 2018-07-10T11:01:29.190616+00:00>, new_state=<state media_player.foxtel_4022=off; friendly_name=Foxtel 4022, supported_features=21437 @ 2018-07-10T11:01:29.550184+00:00>>
2018-07-10 11:01:29 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.yr
2018-07-10 11:01:29 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.yr_symbol, old_state=None, new_state=<state sensor.yr_symbol=unknown; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., friendly_name=yr Symbol, entity_picture=https://api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png @ 2018-07-10T11:01:29.963246+00:00>>
2018-07-10 11:01:31 INFO (MainThread) [homeassistant.setup] Setting up tts
2018-07-10 11:01:32 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-07-10 11:01:33 INFO (MainThread) [homeassistant.setup] Setting up cloud
2018-07-10 11:01:33 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.0 seconds.
2018-07-10 11:01:33 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=cloud>
2018-07-10 11:01:35 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config.config_entries>
2018-07-10 11:01:35 INFO (MainThread) [homeassistant.setup] Setup of domain config took 12.3 seconds.
2018-07-10 11:01:35 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=config>
2018-07-10 11:01:37 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.yr_symbol, old_state=<state sensor.yr_symbol=unknown; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., friendly_name=yr Symbol, entity_picture=https://api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png @ 2018-07-10T11:01:29.963246+00:00>, new_state=<state sensor.yr_symbol=2; attribution=Weather forecast from met.no, delivered by the Norwegian Meteorological Institute., friendly_name=yr Symbol, entity_picture=https://api.met.no/weatherapi/weathericon/1.1/?symbol=2;content_type=image/png @ 2018-07-10T11:01:37.063710+00:00>>
2018-07-10 11:01:37 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 14.4 seconds.
2018-07-10 11:01:37 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sensor>
2018-07-10 11:01:37 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=tts, service=google_say>
2018-07-10 11:01:37 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=tts, service=clear_cache>
2018-07-10 11:01:37 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 6.3 seconds.
2018-07-10 11:01:37 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=tts>
2018-07-10 11:02:08 ERROR (SyncWorker_2) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
core-ssh:~#
Does anyone know what could be causing this?
Have you tried the IP address (in case hassio.local is not resolving).
Have you tried investigating whether 8123 is open? Use nmap from another computer.
Or ssh in and run
sudo netstat -tanp|grep 8123
