I know the topics exist, but WHERE!?
I wasn’t sure where to stick this. So if it’s in the wrongs section, i would really appreciate it if a moderator could move it… Thanks
I have a setup that I want to do, and I know there are answers for each section, but for the life of me I can’t find them again, and I forgot to bookmark them.
I have an event I call Jumpstart. It lasts for 11 days From Monday to a week thursday. I enter the date in my google events calendar.
I have created a trigger helper called Jump Start, a timer helper called ‘Exercise Timer’ for 45 minutes, a timer helper called ‘Water Timer’, and two schedule helpers called ‘Jump Start Schedule’ and ‘Jumpstart Supplementation’ and finally a counter helper called 'Jumpstart Days"
The Jump Start Schedule is set to trigger after 9am, which then runs the water and movement automations on a schedule of every hour for water, and ever 45 minutes until 11pm for excercise.
The Supplementation schedule is set for after 9am, 4pm for drinking my Ningxia Red, and on Monday, Wednesday and Friday at 11 my vitamin supplements.
Enclosed is a Flow Chart:
Basically it takes the event that I enter as “Jump Start is Beginning.” and set the Trigger Helper to ON. Then it calls the water and movement timer, which will run every 1 hour and 45 minutes respectively and triggers based on the Jump Start Helper being on. Then it checks to see if it’s 4pm, and if it is sends custom notifcations to all my devices "Be Sure to Drink You’re Second Dose of Ningxia. I already have a custom message notification automation called ‘Notify Custom Message’.
Finally, at 11pm it adds 1 to the Jump Start Counter and if it equals 11 Stops. If it’s not 11 it goes back to the beginning and does it for the next day.
If anyone has any links that point to simliar topics, i would really appreciate it
