I locked myself out
sorry
I made a change to the http: section in my configuration.yaml and probably did something wrong… because now I can no longer log in locally
Does anyone know how to change the configuration.yaml file on the HAOS command line "HA > "? I have to adjust my http: auth there… I think I then have to call up the “VI” editor… but with LS -la I get an error message that it doesn’t know the command (I just connected the Raspberry directly to Monitor and Keyboard connected and see the command line with the prompt HA >
It should be ls -la (case matters in Linux). You can also just use vi configuration.yaml (I’m not certain, but I think you can also use nano, which is a much easier editor in Linux if you don’t want to deal with vi).
Hello
I don’t know if I installed nano… I wanted to… but I’m not sure.
unfortunately it works
LS -la not
I only see
HA>
if I
HA > Entering Ls -la brings something from the CLI and ls–help, but both lead to nothing…
Do I have to register first?
How ?
o I only see the prompt but it doesn’t understand LS -la or cd config/
I tried it again
He apparently only knows something about
HA > ha update
or
ha restart
but he brings that in
ls -la then he says unknown command
First enter
login
Then you can use vi
Thanks… I was struggling with HAOS commands there… hahaha
sorry im not a professional…
i take now
login
ok i logged in i see the root from a linux machine… but where i can find the homeassistant config directory ?
find / -name "configuration.yaml"
Hello
sure? he list now millions of files… rund and run… thats normal?
and if any have any informations about VI on command line … safe change exit…and what need… thanks a lot for any help
if i try to edit now with VI … and i try to :wq command then Vi told me … :wq is not implemented
why?
need some help more please:
i change now my condiguration.yaml…
i see now tzhe login… but sorry i forget my username… i never logged in only one time then safe that my browser maybe…
i have the password but the user homeassitant don’t like my password… grrrr
what i can do?
i try the
auth list
command ut that now work on my command line
ok all ok
i try that and get username
  1. type login at the ha > prompt
  2. cd to your config directory (where configuration.yaml is located)
  3. grep username .storage/auth
