I lost automations and configuration.yaml
Normally you should try to give more information and provide context to enable us to help you better.
But…
Do you have any way to access the file system for your HA config folder?
It seems like visual studio code cannot find the config folder or is in trouble. It may not mean they arent there anymore. Have you tried restarting the visual code addon if that is what you use? Or if this is an external vistual studio code instance, is the access to the config folder still there, or do you need to reconnect to HA?
Only with Studio Code Server or File Editor
After you restarted VS code addon, also try to clear the browser cache, or try using another browser.
Thanks, Edwin! This solved my problem. It was so simple and I was so stupid…
