I lost my Netatmo Weather sensor las night
Hi
I lost completely all my netatmo weather devices last night. It´s working good with Netatmo app but it seems Hassio can´t connect through Netatmo API.
I rebooted Hassio without success
I see anything in the logs.
It happens the same in my Hassio running in Ubuntu (docker) and my backup raspi.
It´s somenthing happening only to me?
Best regards
Same here. No errors in the log.
Hi !
Me too… I unplugged and plugged again, but nothing !
Few minutes ago, results are came back on the Netatmo application, but not yet in hassio !
Wait and see !
https://helpcenter.netatmo.com/en-us
Tjek problem is do to outage from Netatmo
Same here… there seems to be an issue with this Netatmo cloud service. A good reminder not to base any automations on cloud based services.
EDIT: It seems to be back online now. rebooted Hassio and now everything is back.
Rebooted HA, still doesn’t work for me. Logs show this:
2019-05-08 20:19:56 ERROR (MainThread) [homeassistant.setup] Error during setup of component netatmo
  File "/usr/local/lib/python3.7/site-packages/homeassistant/setup.py", line 156, in _async_setup_component
    component.setup, hass, processed_config)  # type: ignore
  File "/usr/local/lib/python3.7/site-packages/homeassistant/components/netatmo/__init__.py", line 91, in setup
    'read_station read_camera access_camera '
  File "/usr/local/lib/python3.7/site-packages/pyatmo.py", line 85, in __init__
    self._accessToken = resp["access_token"]
TypeError: 'NoneType' object is not subscriptable
Anyone else is having the same?
Resetting client ID/secret helped.
