I dont know why the Hound in GoT didnt like Gingers… RedDragon is my new best buddy.
Thanks @USA-RedDragon for putting this together. Got it working with bells and whistles.
One question I could not get to the bottom of - How do new devices get pulled in when I add them?
Do I need to restart HA entirely or should they just appear?
I just migrated my account from Nest to Google since this component stopped working a few days ago. Just wanted to say that using the Vivaldi browser (chromium based), I didn’t get same results in the developer tools as described in the github readme. When I switched to using Chrome, then I got the proper network requests and was able get the issue_token and cookie values.
Also, it appears that if you leave the email address in the configuration from the nest login, the component won’t actually load still. Once I removed that, then it came up and everything looks good again. Just an FYI for others who migrate.
Had the same question, I added 2 protects and they don’t show up.
What I did do was recheck the token and cookie, and the cookie had changed after I added the new devices. Might be an idea for you to check that out.
I have it up and running. I dont see the camera in the Nest Hub Max, which doesnt bother me so much yet. My primary concern is how to get the Protect to show No Smoke// Smoke and No CO// CO Alert instead o zero or one (I’m assuming its 1- I havent triggered the alarm since adding). I assume I can use some template - but Im not so great with it.
I just moved to the Nest from my old 3M Radio Thermostat, got badnest up and running great thanks @USA-RedDragon. Is there anyway to see when the actual fan is running. On my system I use the fan state to display whether the HVAC is actually running.
Can you find it in the entities under configuration? I did nothing special after the install. Found the entity created by badnest and used it in my picture card. I have the nest hello door camera.
Cameras are broken in the current implementation due a change in APIs. I have fixed them in my pull request so you can take it from there or wait for it to be merged.
Hey, Thanks for making the changes, my doorbell is working as well. Ive noticed that if let my UI sit that the camera stops updating and the image goes away. Its fixed by having another browser window open logged into home.nest.com. Then, if home.nest.com stops updating the camera image, the image goes away om my HA webpage.
My first attempt at using badnest, was unable to get my NEST Email & Password working… no 2FA enabled, tested account with web site & smart phone app – they get in fine. I converted to Google Account followed the instructions and badnest worked on the 1st try. Found my Thermostat and two protect units.
