I made a Laser tower for my cat 😍
Demo:
Features:
  • One Switch available on home-assistant to turn on / off the tower (Both LED and Servomotors)
  • Random movement of both motors
Parts:
  • A Pan/Tilt combo that you can find online easily (I used that one)
  • A Laser module (I used that one)
  • An ESP32 board (I used that one)
ESP32 Code (ESPHome framework):
esphome:
  platform: ESP32
  board: esp-wrover-kit
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_pwd
  ap:
    ssid: "Laser Tower Fallback Hotspot"
    password: !secret esphome_ap_pwd
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: !secret esphome_api_pwd
ota:
  password: !secret esphome_ota_pwd
output:
  - platform: ledc
    pin: GPIO13
    frequency: 50Hz
  - platform: ledc
    pin: GPIO12
    frequency: 50Hz
servo:
  - id: my_servo_1
    output: gpio_13
  - id: my_servo_2
    output: gpio_12
switch:
  - platform: gpio
    pin: GPIO14
    name: "Laser Schrodie"
    on_turn_on:
      - while:
          condition:
            switch.is_on: switch_laser
          then:
            - servo.write:
                level: !lambda |-
                  static int position_1 = 0;
                  position_1 = min( max( int(position_1 + (rand() % 3) - 1) , -100), 100);
                  return position_1 / 100.0;
            - servo.write:
                level: !lambda |-
                  static int position_2 = -40;
                  position_2 = min( max( int(position_2 + (rand() % 3) - 1) , -80), 0);
                  return position_2 / 100.0;
            - delay: 100ms
I’ll try to capture my cat playing with it but right now … she’s sleeping :smiley:
Initial inspiration (Arduino based) : here
