I know there is a integration for this, but it is not showing uptime and processes ect., so i set up with REST-sensors and TEMPLATE sensors and made this in lovelace, I think it looks good.
I wrote about it here (YAML included):
Thanks for the share, I’m following your tutorial on your blog but I’m confused how to add Lovelace code in my own HA. Am I supposed to copy/paste the whole Lovelace code in my Lovelace yaml file ? as it creates some duplicate keys
Ah thanks had missed that element Have pasted code and now it starts to work but I have to adapt the rest sensors for my computer configuration
Good Just change IP, and replace “SERVER”/“server” with the name of our server ect.
Yep adapted configuration for my laptop (test with that computer) and here is result:
Going to do the same with all my servers to keep easily an eye on all of them
Thanks again for that nice trick
Firstly, thank you so much for this, I’ve been trying to monitor other Pi’s stats with no success and this worked perfectly.
I’ve run into an issue. I first setup the Pi last month which works flawlessly and now I’m only just setting up another install but I can’t even install glances. I’m running Python3, latest. I’ve installed Pip for 2 and 3 but always get this error. Any idea’s?
I honestly can’t remember if I installed any other dependencies to get it working but this time I installed psutil but still the same error. Should this work with Python3 or do I need 2? sorry for all the questions
EDIT:
I think it may be Bullseye. Well, that was some chasing my tail. It appears glances does not currently work with the new OS. Will update tomorrow. Thanks
Hi
PI 4 with bullseye and python 3.9 here…
did you try to install via pip3 instead of downloading the install script with curl?
pip3 install glances
for the web interface I also had to install the “bottle”-package with pip3
Armin
I did. Any pip install throws up errors. Forgot what I tried now but multiple ways and couldn’t get it to work. Then read Glances doesn’t work with Bulleye
EDIT:
I redid everything with Buster and all went as smooth as before, thanks again!
Think I’ll try on another sd card with Bullseye at somepoint.
how can I install glances in Home Assistant OS?
You don’t have to install anything: it is a standard lovelace card
Well, that is not the same, Glances is a software to report system resources, Glance (card) is a way to view sensors.
But the Glance card can show data from Glances
Sorry my mistake, thought that it might have been a language issue…
