Hi Everyone.
I like to seek a help here to understand what I read from zigbee2mqtt documentation. FYI, english is not my 1st language.
The current state of this switch is in the published state under the state_left
property (value is ON
or OFF
). To control this switch publish a message to topic zigbee2mqtt/FRIENDLY_NAME/set
with payload {"state_left": "ON"}
, {"state_left": "OFF"}
or {"state_left": "TOGGLE"}
I need to understand where should i put this configuration? Is it in the configuration.yaml?
Actually Im trying to experiment whether I can solve my wall switch issue which is currently not update the device state in home assistant if I press manually on the switch.
Thanks.
