Obviously I need something that works well in HA. Thanks!
Did you ever find one to use? I am in the sane boat atm… Looking for a humidifier for a grow room setup…
https://www.amazon.com/LEVOIT-Humidifiers-Ultrasonic-Vaporizer-Essential/dp/B08HS45N13/
It works with the vesync integration.
Oh thank you! I already happen to have a Levoit Humidifier with Vesync and I haven’t had any luck with it. Is there a link to the code or you’re still workin got it? My vesync doesn’t find my Levoit . How did you go about it?
All I did was add it into the app on my phone and then added the removed and re-added the integration into HA. IIRC, HA had to be a version > 0.116. But beyond that, it works. I also have the Levoit Air Purifier that works as well.
I have the latest version of HA. I did the same and it doesn’t find anything. I’ve reinstalled the VeSync a couple of times with no luck. I add my login info into VeSync and it says success then nothing, is that an older version of HA you’re using?
