My json string as appears in mqtt explorer is like so:
{"channel":0,"from":1129875684,"hop_start":3,"hops_away":0,"id":1696352969,"payload":{"hardware":43,"id":"!435888e4","longname":"WarmCat Loft Station","shortname":"CAT"},"sender":"!435888e4","timestamp":1722286203,"to":862545120,"type":"nodeinfo"}
Within a file mqtt.yaml I have the following:
- name: "Node Info Log"
unique_id: "node_info_log"
state_topic: "msh/EU_868/2/json/LongFast/!435888e4"
value_template: >-
{% if value_json.type == 'nodeinfo' %}
{{ value_json.payload.shortname }}
{% else %}
{{ this.state }}
{% endif %}
json_attributes_template: >-
"channel": {{ value_json.channel | default('None') }},
"from": {{ value_json.from | default('None') }},
"hop_start": {{ value_json.hop_start | default('None') }},
"hops_away": {{ value_json.hops_away | default('None') }},
"id": {{ value_json.id | default('None') }},
"hardware": {{ value_json.payload.hardware | default('None') }},
"node_id": "{{ value_json.payload.id | default('None') }}",
"longname": "{{ value_json.payload.longname | default('None') }}",
"shortname": "{{ value_json.payload.shortname | default('None') }}",
"rssi": {{ value_json.rssi | default('None') }},
"sender": "{{ value_json.sender | default('None') }}",
"snr": {{ value_json.snr | default('None') }},
"timestamp": {{ value_json.timestamp | default('None') }},
"to": {{ value_json.to | default('None') }}
{% else %}
{% endif %}
What is it that I’m doing wrong? When I look in developer tools, States, and then look for sensor.node_info_log, I see under ‘State’ the correct value_json.payload.shortname, but the only attribute I see is friendly_name: Node Info Log.
I have a lot of programming experience, alas none of it in yaml.
Thanks in advance if anyone can show me where I’ve went wrong here.
