I am using Actiontiles on an iPad and one of my colored bulbs is a tuya bulb. I created a virtual rgbw light switch in SmartThings that I want to mirror the state of the bulb in Home Assistant and vice versa. I edited my automation.yaml file and can get the switches to turn on and off together but I can’t seem to figure out how to pass the color attributes between the two. This is the post I used as reference:
This is my automation.yaml file:
- alias: Mirror Master Light Color 1
initial_state: 'on'
platform: state
entity_id: light.masterlight
condition:
condition: template
value_template: "{{ trigger.to_state.state != 'off' }}"
service_template: light.turn_on
entity_id: light.master_light
data_template:
brightness: '{{states.light.masterlight.attributes.brightness |int}}'
xy_color: [
'{{states.light.masterlight.attributes.xy_color[0] |float}}',
'{{states.light.masterlight.attributes.xy_color[1] |float}}'
hs_color: [
'{{states.light.masterlight.attributes.hs_color[0] |float}}',
'{{states.light.masterlight.attributes.hs_color[1] |float}}'
rgb_color: [
'{{states.light.masterlight.attributes.rgb_color[0] |int}}',
'{{states.light.masterlight.attributes.rgb_color[1] |int}}',
'{{states.light.masterlight.attributes.rgb_color[2] |int}}'
- alias: Mirror Master Light Color 2
initial_state: 'on'
platform: state
condition:
condition: template
data_template:
brightness: '{{states.light.master_light.attributes.brightness |int}}'
xy_color: [
'{{states.light.master_light.attributes.xy_color[0] |float}}',
'{{states.light.master_light.attributes.xy_color[1] |float}}'
hs_color: [
'{{states.light.master_light.attributes.hs_color[0] |float}}',
'{{states.light.master_light.attributes.hs_color[1] |float}}'
rgb_color: [
'{{states.light.master_light.attributes.rgb_color[0] |int}}',
'{{states.light.master_light.attributes.rgb_color[1] |int}}',
'{{states.light.master_light.attributes.rgb_color[2] |int}}'
- alias: Mirror Master Light On 1
initial_state: 'on'
platform: state
to: "off"
service: light.turn_off
- alias: Mirror Master Light On 2
initial_state: 'on'
platform: state
to: "off"
- alias: Mirror Master Light Off 1
initial_state: 'on'
platform: state
to: "on"
service: light.turn_on
- alias: Mirror Master Light Off 2
initial_state: 'on'
platform: state
to: "on"
Please help! Thank you
