I have made an anemometer. I have it working on an arduino uno and I get readings in the serial monitor on Arduino IDE.
What I would like to do is add the anemometer to the weather station that I currently have working in HA. This means that I need to change from using the Arduino UNO coding to YAML for HA. I am using a Wemos D1 as the controller in the Weather Station.
I am using a electric motor connected to a 3d printed anemometer that generates a current when the wind blows.
This is the Arduino coding.
Only two pins used
Positive to A0 on the UNO
Ground to GND on the UNO
int ledPin = 9;
void setup() {
Serial.begin(9600);
void loop() {
int sensorValue = analogRead(A0);
//Map 0-1023 to discrete 0-50-100...250 values for LED
analogWrite(ledPin, sensorValue * (51.0 / 1023.0) * 50);
if(sensorValue > 0){
Serial.println(sensorValue);
Serial.print(" ");
My current Weather Station YAML looks like this
esphome:
platform: ESP8266
board: d1
wifi:
ssid: "my ssid"
password: "my password"
ap:
ssid: "Mainweatherstation"
password: "DlafFcP9W8ct"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
i2c:
sda: D14
scl: D15
scan: True
- platform: dht
model: dht11
pin: D7
temperature:
name: "Weather Station Temperature"
humidity:
name: "Weather Station Humidity"
update_interval: 5s
- platform: bmp085
pressure:
name: "Outside Pressure"
temperature:
name: "Weather Station Temperature Main"
update_interval: 5s
I would greatly appreciate any assistant.
