I need help my Home Assistant on RPI 5 8 GB does not install: Supervisor no Internet
As he wrote I am trying to install an assistant on a Raspberry Pi 5 8 GB but without succeeding as I do not install the addons at the time of the general installation. Supervisor No Internet Connection
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[10:58:29] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[10:58:29] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
23-04-04 10:58:32 INFO (MainThread) [__main__] Initializing Supervisor setup
23-04-04 10:58:32 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-04-04 10:58:32 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi5-64
23-04-04 10:58:32 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.03.0
23-04-04 10:58:32 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-04-04 10:58:32 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-04-04 10:58:32 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 10:58:32 INFO (MainThread) [__main__] Setting up Supervisor
23-04-04 10:58:32 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-04-04 10:58:32 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-04-04 10:58:32 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-04-04 10:58:32 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-04-04 10:58:32 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-04-04 10:58:32 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-04-04 10:58:32 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-04-04 10:58:32 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-04-04 10:58:32 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-04-04 10:58:32 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-04-04 10:58:32 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-04-04 10:58:33 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 10:58:33 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 10:58:33 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
23-04-04 10:58:33 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 10:58:33 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-04-04 10:58:33 WARNING (MainThread) [supervisor.utils.whoami] Whoami service failed with SSL verification: Cannot connect to host services.home-assistant.io:443 ssl:True [SSLCertVerificationError: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1000)')]
23-04-04 10:58:33 INFO (MainThread) [supervisor.core] Whoami service SSL error
23-04-04 12:58:33 WARNING (MainThread) [supervisor.core] System time/date shift over more than 3 days found!
23-04-04 12:58:33 INFO (MainThread) [supervisor.host.control] Setting new host datetime: 2024-05-09T15:36:05+00:00
23-04-04 12:58:33 CRITICAL (MainThread) [supervisor.core] Fatal error happening on load Task <coroutine object Core._adjust_system_datetime at 0x7fa0349c60>: Automatic time synchronization is enabled
23-04-04 12:58:33 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-04-04 12:58:33 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 12:58:33 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-cli versions: [<AwesomeVersion CalVer '2024.03.1'>]
23-04-04 12:58:33 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1
23-04-04 12:58:33 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-04-04 12:58:34 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1 - 172.30.32.5
23-04-04 12:58:34 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-dns versions: [<AwesomeVersion CalVer '2024.03.0'>]
23-04-04 12:58:34 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0
23-04-04 12:58:34 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-04-04 12:58:35 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0 - 172.30.32.3
23-04-04 12:58:35 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-04-04 12:58:35 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-audio versions: [<AwesomeVersion CalVer '2023.12.0'>]
23-04-04 12:58:35 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
23-04-04 12:58:35 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-04-04 12:58:36 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
23-04-04 12:58:36 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-04-04 12:58:36 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
23-04-04 12:58:36 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-04-04 12:58:38 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0 - 172.30.32.6
23-04-04 12:58:38 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/aarch64-hassio-multicast versions: [<AwesomeVersion CalVer '2024.03.0'>]
23-04-04 12:58:38 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0
23-04-04 12:58:38 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-04-04 12:58:39 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
23-04-04 12:58:39 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-04-04 12:58:39 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/raspberrypi5-64-homeassistant
23-04-04 12:58:39 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/raspberrypi5-64-homeassistant found.
23-04-04 12:58:39 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi5-64-homeassistant with version landingpage
23-04-04 12:58:39 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-04-04 12:58:39 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-04-04 12:58:39 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-04-04 12:58:40 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi5-64-homeassistant with version landingpage
23-04-04 12:58:40 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.1 / BootSlot A
23-04-04 12:58:40 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 12:58:40 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/hassio-addons/repository due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / a0d7b954
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
23-04-04 12:58:40 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/esphome/home-assistant-addon due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / 5c53de3b
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
23-04-04 12:58:40 ERROR (MainThread) [supervisor.store] Can't add repository core due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / core
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
23-04-04 12:58:40 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-04-04 12:58:40 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
23-04-04 12:58:40 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-04-04 12:58:40 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-04-04 12:58:40 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 12:58:40 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - setup
23-04-04 12:58:40 INFO (MainThread) [__main__] Running Supervisor
23-04-04 12:58:40 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention!
23-04-04 12:58:40 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-04-04 12:58:40 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
23-04-04 12:58:40 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
23-04-04 12:58:40 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
23-04-04 12:58:40 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
23-04-04 12:58:40 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
23-04-04 12:58:40 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-04-04 12:58:40 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-04-04 12:58:40 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-04-04 12:58:40 INFO (MainThread) [supervisor.host.info] Updating local host information
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-04-04 12:58:40 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 12:58:40 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 12:58:40 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 12:58:40 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-04-04 12:58:40 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 12:58:40 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 12:58:40 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-04-04 12:58:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-04-04 12:58:41 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
23-04-04 12:58:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-04-04 12:58:41 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
23-04-04 12:58:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-04-04 12:58:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-04-04 12:58:41 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
23-04-04 12:58:41 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
23-04-04 12:58:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-04-04 12:58:41 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-04-04 12:58:41 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 12:58:41 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-04-04 12:58:41 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 12:58:41 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - setup
23-04-04 12:59:10 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 12:59:10 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 12:59:41 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 12:59:41 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:00:11 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:00:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:00:41 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:00:41 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:01:11 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:01:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:01:41 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:01:41 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:02:11 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:02:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:02:42 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:02:42 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:03:12 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:03:12 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:03:44 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:03:44 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:04:14 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:04:14 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:04:44 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:04:44 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:05:15 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:05:15 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:05:46 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:05:46 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:06:16 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:06:16 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:06:46 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:06:46 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:07:16 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:07:16 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:07:46 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:07:46 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:08:10 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/002 - None
23-04-04 13:08:10 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/input/event1 - /dev/input/by-id/usb-Corsair_CORSAIR_K55_RGB_PRO_Gaming_Keyboard_F5001BC65F63E0AAAF7A8C631301E025-event-kbd
23-04-04 13:08:10 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/hidraw0 - None
23-04-04 13:08:10 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/usb/hiddev0 - None
23-04-04 13:08:10 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/hidraw1 - None
23-04-04 13:08:10 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/usb/hiddev1 - None
23-04-04 13:08:10 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/hidraw2 - None
23-04-04 13:08:17 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:08:17 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:08:47 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:08:47 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:09:17 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:09:17 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:09:47 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:09:47 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
[11:11:31] INFO: Using udev information from host
[11:11:31] INFO: Starting local supervisor watchdog...
23-04-04 11:11:33 INFO (MainThread) [__main__] Initializing Supervisor setup
23-04-04 13:11:33 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi5-64
23-04-04 13:11:33 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.03.0
23-04-04 13:11:33 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-04-04 13:11:33 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 13:11:33 INFO (MainThread) [__main__] Setting up Supervisor
23-04-04 13:11:33 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-04-04 13:11:33 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-04-04 13:11:33 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-04-04 13:11:33 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-04-04 13:11:33 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-04-04 13:11:33 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-04-04 13:11:33 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-04-04 13:11:33 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-04-04 13:11:33 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-04-04 13:11:33 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-04-04 13:11:33 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-04-04 13:11:34 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 13:11:34 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 13:11:34 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
23-04-04 13:11:34 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 13:11:34 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-04-04 13:11:34 WARNING (MainThread) [supervisor.utils.whoami] Whoami service failed with SSL verification: Cannot connect to host services.home-assistant.io:443 ssl:True [SSLCertVerificationError: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1000)')]
23-04-04 13:11:34 INFO (MainThread) [supervisor.core] Whoami service SSL error
23-04-04 13:11:34 WARNING (MainThread) [supervisor.core] System time/date shift over more than 3 days found!
23-04-04 13:11:34 INFO (MainThread) [supervisor.host.control] Setting new host datetime: 2024-05-09T15:50:16+00:00
23-04-04 13:11:34 CRITICAL (MainThread) [supervisor.core] Fatal error happening on load Task <coroutine object Core._adjust_system_datetime at 0x7f9cef93f0>: Automatic time synchronization is enabled
23-04-04 13:11:34 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-04-04 13:11:34 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:11:34 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1
23-04-04 13:11:34 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-04-04 13:11:34 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
23-04-04 13:11:35 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1 - 172.30.32.5
23-04-04 13:11:35 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0
23-04-04 13:11:35 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-04-04 13:11:35 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
23-04-04 13:11:37 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0 - 172.30.32.3
23-04-04 13:11:37 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-04-04 13:11:37 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
23-04-04 13:11:37 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-04-04 13:11:37 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
23-04-04 13:11:38 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
23-04-04 13:11:38 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
23-04-04 13:11:38 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0
23-04-04 13:11:38 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-04-04 13:11:38 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
23-04-04 13:11:39 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
23-04-04 13:11:39 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-04-04 13:11:39 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi5-64-homeassistant with version landingpage
23-04-04 13:11:39 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-04-04 13:11:39 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-04-04 13:11:40 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.1 / BootSlot A
23-04-04 13:11:40 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 13:11:40 ERROR (MainThread) [supervisor.store] Can't add repository core due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / core
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
23-04-04 13:11:40 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/esphome/home-assistant-addon due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / 5c53de3b
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
23-04-04 13:11:40 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/hassio-addons/repository due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / a0d7b954
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
23-04-04 13:11:40 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-04-04 13:11:40 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
23-04-04 13:11:40 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-04-04 13:11:40 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-04-04 13:11:40 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 13:11:40 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - setup
23-04-04 13:11:40 INFO (MainThread) [__main__] Running Supervisor
23-04-04 13:11:40 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention!
23-04-04 13:11:40 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-04-04 13:11:40 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
23-04-04 13:11:40 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
23-04-04 13:11:40 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
23-04-04 13:11:40 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
23-04-04 13:11:40 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
23-04-04 13:11:40 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-04-04 13:11:40 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-04-04 13:11:40 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-04-04 13:11:40 INFO (MainThread) [supervisor.host.info] Updating local host information
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-04-04 13:11:40 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 13:11:40 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 13:11:40 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 13:11:40 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-04-04 13:11:40 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:11:40 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:11:40 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-04-04 13:11:40 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-04-04 13:11:40 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-04-04 13:11:40 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-04-04 13:11:41 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 13:11:41 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - setup
23-04-04 13:12:10 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:12:10 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:12:40 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:12:40 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:13:10 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:13:10 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:13:41 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:13:41 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:14:05 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 13:14:11 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:14:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:14:16 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 13:14:41 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:14:41 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:14:55 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.12/site-packages/voluptuous/validators.py", line 127, in __call__
    return self.type(v)
  File "/usr/local/lib/python3.12/ipaddress.py", line 54, in ip_address
    raise ValueError(f'{address!r} does not appear to be an IPv4 or IPv6 address')
ValueError: '192.168.178.1/24' does not appear to be an IPv4 or IPv6 address
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
    return await handler(request)
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 189, in block_bad_requests
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 205, in system_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 272, in token_validation
  File "/usr/src/supervisor/supervisor/api/middleware/security.py", line 283, in core_proxy
  File "/usr/src/supervisor/supervisor/api/utils.py", line 63, in wrap_api
    answer = await method(api, *args, **kwargs)
  File "/usr/src/supervisor/supervisor/api/network.py", line 193, in interface_update
    body = await api_validate(SCHEMA_UPDATE, request)
  File "/usr/src/supervisor/supervisor/api/utils.py", line 159, in api_validate
    data_validated = schema(data)
  File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 281, in __call__
    return self._compiled([], data)
  File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 625, in validate_dict
    return base_validate(path, data.items(), out)
  File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 406, in validate_mapping
    cval = cvalue(key_path, value)
  File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 855, in validate_callable
    return schema(data)
    return schema(data)
  File "/usr/local/lib/python3.12/site-packages/voluptuous/validators.py", line 130, in __call__
    if not self.msg and Enum and issubclass(self.type, Enum):
TypeError: issubclass() arg 1 must be a class
23-04-04 13:15:06 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 13:15:11 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:15:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:15:41 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:15:41 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:16:11 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:16:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:16:42 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:16:42 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:17:12 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:17:12 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:17:12 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 13:17:42 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:17:42 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:18:12 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:18:12 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:18:42 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:18:42 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:19:12 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:19:12 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:19:43 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:19:43 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:20:13 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:20:13 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:20:43 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:20:43 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:21:13 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:21:13 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:21:43 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:21:43 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:22:13 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:22:13 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:22:44 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:22:44 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:23:14 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:23:14 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:23:44 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:23:44 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:24:14 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:24:14 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:24:44 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:24:44 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:25:14 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:25:14 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:25:45 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:25:45 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:26:15 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:26:15 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:26:45 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:26:45 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:27:15 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:27:15 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
[11:29:01] INFO: Using udev information from host
[11:29:01] INFO: Starting local supervisor watchdog...
23-04-04 11:29:03 INFO (MainThread) [__main__] Initializing Supervisor setup
23-04-04 13:29:04 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi5-64
23-04-04 13:29:04 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2024.03.0
23-04-04 13:29:04 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-04-04 13:29:04 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 13:29:04 INFO (MainThread) [__main__] Setting up Supervisor
23-04-04 13:29:04 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-04-04 13:29:04 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-04-04 13:29:04 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-04-04 13:29:04 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-04-04 13:29:04 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-04-04 13:29:04 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-04-04 13:29:04 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-04-04 13:29:04 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-04-04 13:29:04 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-04-04 13:29:04 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-04-04 13:29:04 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-04-04 13:29:04 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 13:29:04 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 13:29:04 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
23-04-04 13:29:04 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 13:29:04 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-04-04 13:29:04 WARNING (MainThread) [supervisor.utils.whoami] Whoami service failed with SSL verification: Cannot connect to host services.home-assistant.io:443 ssl:True [SSLCertVerificationError: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1000)')]
23-04-04 13:29:04 INFO (MainThread) [supervisor.core] Whoami service SSL error
23-04-04 13:29:04 WARNING (MainThread) [supervisor.core] System time/date shift over more than 3 days found!
23-04-04 13:29:04 INFO (MainThread) [supervisor.host.control] Setting new host datetime: 2024-05-09T16:19:48+00:00
23-04-04 13:29:04 CRITICAL (MainThread) [supervisor.core] Fatal error happening on load Task <coroutine object Core._adjust_system_datetime at 0x7f9b3a13f0>: Automatic time synchronization is enabled
23-04-04 13:29:04 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-04-04 13:29:05 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:29:05 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1
23-04-04 13:29:05 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-04-04 13:29:05 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
23-04-04 13:29:05 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/aarch64-hassio-cli with version 2024.03.1 - 172.30.32.5
23-04-04 13:29:05 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0
23-04-04 13:29:05 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-04-04 13:29:05 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
23-04-04 13:29:06 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2024.03.0 - 172.30.32.3
23-04-04 13:29:06 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-04-04 13:29:07 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0
23-04-04 13:29:07 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-04-04 13:29:07 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
23-04-04 13:29:08 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/aarch64-hassio-audio with version 2023.12.0 - 172.30.32.4
23-04-04 13:29:08 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2023.06.0
23-04-04 13:29:08 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0
23-04-04 13:29:08 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-04-04 13:29:08 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
23-04-04 13:29:09 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/aarch64-hassio-multicast with version 2024.03.0 - Host
23-04-04 13:29:09 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-04-04 13:29:09 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi5-64-homeassistant with version landingpage
23-04-04 13:29:09 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-04-04 13:29:09 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting...
23-04-04 13:29:09 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.1 / BootSlot A
23-04-04 13:29:09 INFO (SyncWorker_0) [supervisor.docker.manager] Starting homeassistant
23-04-04 13:29:09 WARNING (MainThread) [supervisor.jobs] 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 13:29:09 ERROR (MainThread) [supervisor.store] Can't add repository core due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 13:29:09 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / core
23-04-04 13:29:09 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
23-04-04 13:29:09 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/hassio-addons/repository due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 13:29:09 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / a0d7b954
23-04-04 13:29:09 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
23-04-04 13:29:09 ERROR (MainThread) [supervisor.store] Can't add repository https://github.com/esphome/home-assistant-addon due to 'GitRepo.clone' blocked from execution, no supervisor internet connection
23-04-04 13:29:09 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / 5c53de3b
23-04-04 13:29:09 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
23-04-04 13:29:09 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-04-04 13:29:09 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
23-04-04 13:29:09 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-04-04 13:29:09 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-04-04 13:29:09 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-04-04 13:29:09 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-04-04 13:29:09 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 13:29:09 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-04-04 13:29:09 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 13:29:09 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - setup
23-04-04 13:29:09 INFO (MainThread) [__main__] Running Supervisor
23-04-04 13:29:09 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention!
23-04-04 13:29:10 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-04-04 13:29:10 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
23-04-04 13:29:10 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
23-04-04 13:29:10 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
23-04-04 13:29:10 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
23-04-04 13:29:10 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
23-04-04 13:29:10 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-04-04 13:29:10 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-04-04 13:29:10 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-276' coro=<HomeAssistantCore.install() done, defined at /usr/src/supervisor/supervisor/jobs/decorator.py:190> exception=HomeAssistantJobError('Another job is running for job group home_assistant_core')>
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 239, in wrapper
    await obj.acquire(
  File "/usr/src/supervisor/supervisor/jobs/job_group.py", line 58, in acquire
    raise JobGroupExecutionLimitExceeded(
supervisor.exceptions.JobGroupExecutionLimitExceeded: Another job is running for job group home_assistant_core
  File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 244, in wrapper
    raise self.on_condition(str(err)) from err
supervisor.exceptions.HomeAssistantJobError: Another job is running for job group home_assistant_core
23-04-04 13:29:10 INFO (MainThread) [supervisor.host.info] Updating local host information
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-04-04 13:29:10 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 13:29:10 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 13:29:10 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 13:29:10 WARNING (SyncWorker_1) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
23-04-04 13:29:10 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-04-04 13:29:10 WARNING (MainThread) [supervisor.jobs] 'Updater.fetch_data' blocked from execution, no supervisor internet connection
23-04-04 13:29:10 INFO (MainThread) [supervisor.jobs] 'CheckAddonPwned.run_check' blocked from execution, no supervisor internet connection
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-04-04 13:29:10 INFO (MainThread) [supervisor.jobs] 'CheckDNSServer.run_check' blocked from execution, no supervisor internet connection
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-04-04 13:29:10 INFO (MainThread) [supervisor.jobs] 'CheckDNSServerIPv6.run_check' blocked from execution, no supervisor internet connection
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-04-04 13:29:10 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 13:29:10 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not healthy - setup
23-04-04 13:31:15 INFO (MainThread) [supervisor.plugins.dns] Restarting CoreDNS plugin
23-04-04 13:31:15 INFO (SyncWorker_1) [supervisor.docker.manager] Restarting hassio_dns
23-04-04 13:31:21 INFO (MainThread) [supervisor.plugins.dns] Restarting CoreDNS plugin
23-04-04 13:31:21 ERROR (MainThread) [supervisor.plugins.dns] Can’t start CoreDNS plugin
23-04-04 13:31:27 INFO (MainThread) [supervisor.plugins.dns] Restarting CoreDNS plugin
23-04-04 13:31:27 INFO (SyncWorker_0) [supervisor.docker.manager] Restarting hassio_dns
23-04-04 13:32:10 INFO (MainThread) [supervisor.host.network] Updating local network information
[11:34:02] INFO: Using udev information from host
[11:34:02] INFO: Starting local supervisor watchdog…
23-04-04 11:34:05 INFO (MainThread) [main] Initializing Supervisor setup
23-04-04 13:34:05 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: raspberrypi5-64
23-04-04 13:34:05 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor Package aarch64-hassio-supervisor · GitHub with version 2024.03.0
23-04-04 13:34:05 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-04-04 13:34:05 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 13:34:05 INFO (MainThread) [main] Setting up Supervisor
23-04-04 13:34:05 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-04-04 13:34:05 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-04-04 13:34:05 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-04-04 13:34:05 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-04-04 13:34:05 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-04-04 13:34:05 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-04-04 13:34:05 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-04-04 13:34:05 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-04-04 13:34:05 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-04-04 13:34:05 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-04-04 13:34:05 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-04-04 13:34:05 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 13:34:05 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 13:34:05 WARNING (SyncWorker_0) [supervisor.host.sound] Can’t update PulseAudio data: Failed to connect to pulseaudio server
23-04-04 13:34:05 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 13:34:05 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {‘hassio-supervisor’}
23-04-04 13:34:05 WARNING (MainThread) [supervisor.utils.whoami] Whoami service failed with SSL verification: Cannot connect to host services.home-assistant.io:443 ssl:True [SSLCertVerificationError: (1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1000)’)]
23-04-04 13:34:05 INFO (MainThread) [supervisor.core] Whoami service SSL error
23-04-04 13:34:05 WARNING (MainThread) [supervisor.core] System time/date shift over more than 3 days found!
23-04-04 13:34:05 INFO (MainThread) [supervisor.host.control] Setting new host datetime: 2024-05-09T16:25:40+00:00
23-04-04 13:34:05 CRITICAL (MainThread) [supervisor.core] Fatal error happening on load Task <coroutine object Core._adjust_system_datetime at 0x7f8c1593f0>: Automatic time synchronization is enabled
23-04-04 13:34:05 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-04-04 13:34:06 WARNING (MainThread) [supervisor.jobs] ‘Updater.fetch_data’ blocked from execution, no supervisor internet connection
23-04-04 13:34:06 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-cli · GitHub with version 2024.03.1
23-04-04 13:34:06 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-04-04 13:34:06 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application
23-04-04 13:34:07 INFO (MainThread) [supervisor.docker.cli] Starting CLI Package aarch64-hassio-cli · GitHub with version 2024.03.1 - 172.30.32.5
23-04-04 13:34:07 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-dns · GitHub with version 2024.03.0
23-04-04 13:34:07 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-04-04 13:34:07 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application
23-04-04 13:34:08 INFO (MainThread) [supervisor.docker.dns] Starting DNS Package aarch64-hassio-dns · GitHub with version 2024.03.0 - 172.30.32.3
23-04-04 13:34:08 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-04-04 13:34:08 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-audio · GitHub with version 2023.12.0
23-04-04 13:34:08 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-04-04 13:34:08 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application
23-04-04 13:34:09 INFO (MainThread) [supervisor.docker.audio] Starting Audio Package aarch64-hassio-audio · GitHub with version 2023.12.0 - 172.30.32.4
23-04-04 13:34:09 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-observer · GitHub with version 2023.06.0
23-04-04 13:34:09 INFO (MainThread) [supervisor.docker.interface] Attaching to Package aarch64-hassio-multicast · GitHub with version 2024.03.0
23-04-04 13:34:09 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-04-04 13:34:09 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application
23-04-04 13:34:10 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast Package aarch64-hassio-multicast · GitHub with version 2024.03.0 - Host
23-04-04 13:34:10 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-04-04 13:34:10 INFO (MainThread) [supervisor.docker.interface] Attaching to Package raspberrypi5-64-homeassistant · GitHub with version landingpage
23-04-04 13:34:10 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-04-04 13:34:10 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting…
23-04-04 13:34:10 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.1 / BootSlot A
23-04-04 13:34:10 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant
23-04-04 13:34:10 WARNING (MainThread) [supervisor.jobs] ‘GitRepo.clone’ blocked from execution, no supervisor internet connection
23-04-04 13:34:10 ERROR (MainThread) [supervisor.store] Can’t add repository GitHub - esphome/home-assistant-addon: ESPHome Home Assistant Add-on due to ‘GitRepo.clone’ blocked from execution, no supervisor internet connection
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / 5c53de3b
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
23-04-04 13:34:10 ERROR (MainThread) [supervisor.store] Can’t add repository GitHub - hassio-addons/repository: Home Assistant Community Add-ons due to ‘GitRepo.clone’ blocked from execution, no supervisor internet connection
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / a0d7b954
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
23-04-04 13:34:10 ERROR (MainThread) [supervisor.store] Can’t add repository core due to ‘GitRepo.clone’ blocked from execution, no supervisor internet connection
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_reload - store / core
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
23-04-04 13:34:10 INFO (MainThread) [supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
23-04-04 13:34:10 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
23-04-04 13:34:10 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-04-04 13:34:10 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-04-04 13:34:10 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 13:34:10 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not healthy - setup
23-04-04 13:34:10 INFO (MainThread) [main] Running Supervisor
23-04-04 13:34:10 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention!
23-04-04 13:34:10 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-04-04 13:34:10 INFO (MainThread) [supervisor.addons.manager] Phase ‘initialize’ starting 0 add-ons
23-04-04 13:34:10 INFO (MainThread) [supervisor.addons.manager] Phase ‘system’ starting 0 add-ons
23-04-04 13:34:10 INFO (MainThread) [supervisor.addons.manager] Phase ‘services’ starting 0 add-ons
23-04-04 13:34:10 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
23-04-04 13:34:10 INFO (MainThread) [supervisor.addons.manager] Phase ‘application’ starting 0 add-ons
23-04-04 13:34:10 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-04-04 13:34:10 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-04-04 13:34:10 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-04-04 13:34:10 INFO (MainThread) [supervisor.host.info] Updating local host information
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-04-04 13:34:10 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-04-04 13:34:10 INFO (MainThread) [supervisor.host.services] Updating service information
23-04-04 13:34:10 INFO (MainThread) [supervisor.host.network] Updating local network information
23-04-04 13:34:10 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-04-04 13:34:10 WARNING (SyncWorker_1) [supervisor.host.sound] Can’t update PulseAudio data: Failed to connect to pulseaudio server
23-04-04 13:34:10 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-04-04 13:34:11 WARNING (MainThread) [supervisor.jobs] ‘Updater.fetch_data’ blocked from execution, no supervisor internet connection
23-04-04 13:34:11 INFO (MainThread) [supervisor.jobs] ‘CheckAddonPwned.run_check’ blocked from execution, no supervisor internet connection
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-04-04 13:34:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
23-04-04 13:34:11 INFO (MainThread) [supervisor.jobs] ‘CheckDNSServer.run_check’ blocked from execution, no supervisor internet connection
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-04-04 13:34:11 INFO (MainThread) [supervisor.jobs] ‘CheckDNSServerIPv6.run_check’ blocked from execution, no supervisor internet connection
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-04-04 13:34:11 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-04-04 13:34:11 INFO (MainThread) [supervisor.jobs] ‘ResolutionFixup.run_autofix’ blocked from execution, system is not healthy - setup
Previous thread: My Home Assistant on RPI 5 8 GB does not install: Supervisor no Internet
I’m looking for a solution please help me in that post there is nothing
It has to do with IPv6. Maybe you can temporary disable IPv6 in your router ?
